If it is the Hayman Reece type, with the square insert, you could load it up with WD40, pull the pin, and tie it off to a tree /bollard, and slowly move off.....
Similarly, you could do the same but edge it up to a solid wall, and reverse slowly, to break the seal ( you would have to be careful doing it this way, so that you dont go too hard )
Mic
