Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 170
Thread: DIESEL FUEL + 2T OIL = Superb performance?
  1. #61
    Jan 2014
    tassie
    did it in my freelander took 2 to 3 tanks and the motor runs quieter helped performance and economy a little to still unsure about the cost of 2 stroke and savings of fuel but having a quieter engine helps
    am trying my patrol soon doing some lper km first
  2. #62
    Jan 2014
    tassie
    beed doing this in my freelander mk 1 the bmw motor took 3 to 4 tanks and runs like a dream ever since a lot quieter started this in my gu 3ltr and starting to hear the difference a lot quieter when warm
  3. #63
    Ok seeing this has been dug up I'll start putting in Castrol Active 2t from tomorrow.
    I use penrite 5/40 so noisy when cold, lets see what happens
  4. #64
    Patrol Guru SonOf's Avatar
    Dover, Tasmania
    Will be interested in your finding TD - I just finished a tank with added injector cleaner in it and found the economy improved quite a bit.
    My 99 GU 4.2 is good n rattly so will definitely investigate this
    Seemed like a good idea at the time
  5. #65
    Patrol God Stropp's Avatar
    38 Post(s)
    i use it in mine and find its quieter but no improvement in either fuel or performance but i use it as if its quieter im happy with that and TD i also use penrite. Outboard 2 stroke is no good from what i read it has to be 2t,
  6. The Following User Says Thank You to Stropp For This Useful Post:
    threedogs (7th March 2014)
  7. #66
    Aug 2011
    River Heads Q
    4 Post(s)
    Quote Originally Posted by SonOf View Post
    Will watch results as well
  8. #67
    Expert Dave_H's Avatar
    Nov 2013
    Whyalla S.A
    I started using this last week and can say it's a little quiter more when cold. Fuel economy seems better i recon 100km more out of main tank, using 200:1 but i also cleaned my MAF sensor at the same time which was quite dirty so this is probably helping aswell. After reading this im not sure whether to use it in my 08 CRD though, Thoughts?
    2008 GU6 ST 3.0 CRD Auto, 2" Lift, ARB Bullbar, IPF Spotties, Side Steps, Maxxis 980 A/T, Roof Rack.....................
  9. #68
    I've heard different reports On crd's.
    Something along the lines of an inbuilt water sensors On the Fuel system doesn't like it??
    Now I have no idea of ratios used when issues happen..
    The question which turned me off was,
    If this additive giving me the efficiency to outweigh the extra cost into each tank.
    For me it wasn't..
    Nov 2013
    Whyalla S.A
    I wasn't really to concerned on fuel savings although it would be a bonus but more for the lubrication benefits which if it does would definitley outweigh the extra cost.
    In saying that i think im going to stop using it until i can get more information about using it with the crd's
  11. #70
    Patrol Freak Gecko17's Avatar
    Mar 2013
    How do you guys reckon this would go in the Chevs?
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
