Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Detroit
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Quote Originally Posted by Forced Offroad View Post
    A auto front is not the best option,
    A auto locker from Detroit for remote travel in Aus I believe is a poor option if anything goes wrong...
    Also Detroit are expensive and with the new ARB lockers that are now out a lot stronger and no matter where your travelling in Aus you can always get you hands on ARB or the TJM pro locker around the country..
    Not sure I agree with you totally there, but acknowledge your points.
    My personal thoughts are that yes, the auto in the front means you have to adjust how you drive a little. I tend to flick back to 2WD a lot more than I used to when driving at speeds on the dirt roads, but otherwise do not see any real difference at low speeds.
    Detroit have been building lockers for a long, long time now, and are proven bits of kit. If something 'goes wrong' then a vehicle would have to operate in 2wd, the same as any other vehicle. I personally was more worried about the air-lines, or wire getting damaged, than a cataclysmic failure happening inside the diff. I do acknowledge that both air-lines and a wire can be repaired on the fly though, and hopefully people who use them all carry a spare bit of hose etc.
    Detroit might be expensive compared to Lokka or Spartan etc., but they are a whole lot more substantial than both, and a lot less expensive than ARB, PRO-LOCKER, or E-LOCKER. Last time I looked I could find one online for $699 shipped to my door.
    I would think that getting a replacement locker in a remote location would mean the same (freighting one in), unless you are in a reasonable sized town, where you are right, the ARB etc. is more likely to be in stock. Otherwise it would just be a matter of limping home and sorting it later I would think.
    My 2 cents worth...
  2. The Following User Says Thank You to FNQGU For This Useful Post:
    Paul Tkalec (9th March 2014)
  3. #22
    Expert Gary Vansleve's Avatar
    Sep 2013
    Brisbane
    [QUOTE=BenK;485503
    My 2 cents worth...[/QUOTE]
    Opposite Lock are telling me they would do a Detroit for the price of an elocker
    [/SIGPIC]The old girl like me well past the use by date
  4. #23
    Oct 2011
    Essendon
    Quote Originally Posted by Gary Vansleve View Post
    ......and they'll be pocketing an extra thousand dollars. There is no way a Detroit locker is the same price as an e-locker.
  5. #24
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Yeah, that is ridiculous.
    Go to Just Differentials online, based in the USA. Still $699 shipped to Aus.
  6. #25
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    @ liftlid not all 4x4 destinations have equal ground allowing equal grip
    Without a locker, with open diffs only the back right and front left will turn in 4x4
    at least with a LSD you might get 3 wheels spinning
    That's the point I was making and the reason I run air lockers.
    1 car with F/R air lockers
    1 car with F air locker /R Detroit locker
    1 car with R LSD/ F open
    Even the patrol LSD will struggle if the wheel is off the ground.
  7. #26
    Sep 2013
    Brisbane
    A
    with the new ARB lockers that are now out a lot stronger ..
    Took note of your comment an sussed this out namely forged gears an a new two piece design. As stated am leaning towards the elocker but not yet set in concrete. Also ARB's qoute was not formalised told me would do better on price if I committed. In view of this will go back to ARB an see what unfolds.
    Have used ARB lockers in the past an with my current play toy (cruiser) I have an oil issue in the rear locker that takes the shine off of things. However in saying that I believe the locker was an owner install job an maybe the seals weren't done kosher. (No offence to the previous owner intended . I brought the truck knowing the leak situation)
    Sounds like I am talking myself into ARB ha ha
  8. #27
    I do know Arb have sorted the issue of oil coming back threw the lines and leaks around the diff.
    But from the sounds of it they have just added more o-rings..
    Sep 2013
    Brisbane
    Ok will sus this out as well also note they do a 5 year guarantee
