Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: HELP! - Popping out of First Gear
    Beginner JR1's Avatar
    Feb 2014
    Canberra
    Morning BillsGU, 89gqpatrol4x4 & macca86
    Thanks for the confirmation - I'll look into this on the weekend when I'm servicing the hubs.
    Bearing in mind the ute has done 206,000K I think I'll change them anyway.
    Can anyone recommend a supplier?
    Cheers fellas
  2. #12
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Quote Originally Posted by JR1 View Post
    Cheers fellas
    Some of these bushes are special to type and (unfortunately) the only place you may be able to get them is Nissan. I have seen selector bush kits at Rare Spares - but they were only for older model fords and holdens. Once you get them out measure them with a vernier and have a look around on the web - you never know.
  3. The Following User Says Thank You to BillsGU For This Useful Post:
    JR1 (26th February 2014)
  4. #13
    This happens to me in 3rd when the gearbox is warm.. So in my circumstance I'd say my box needs repairing..
    Will be changing out oil soon so will see if that helps, but I doubt it..
    I replaced the nylon bushes on the geat stick selector but still no change. Just made the stick less sloppy..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
  6. #14
    Feb 2014
    Canberra
    Hey Westy - I recently changed my gearbox and transfer box oils with Red Line gear oil. A bit expensive bit highly recommend the stuff. Has reduced the slight noise I was experiencing when driving and I can now shift smoothly between gears where before there was a slight difficulty selecting first. Something to consider mate.
  7. #15
    Again not 100% but I vaguely remember being told 1st has no syncro so down shifting is difficult..
    Yea unsure if I'll go a synthetic or mineral oil..
    I'll keep your choice in mind thou thanks
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
  9. #16
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Mine did it when coasting down hill in 3rd as you took your foot off throttle, only seemed to do it off road but it did get a flogging, swapped out gear box and it solved problem.
  10. The Following 2 Users Say Thank You to liftlid For This Useful Post:
    BigRAWesty (26th February 2014), JR1 (26th February 2014)
  11. #17
    Feb 2014
    Canberra
    Hopfully it won't come to that liftlid as I'm feeling as though time's getting away from me to have everything done before the June trip to Vic High Country
  12. #18
    Jul 2010
    Thurgoona
    7 Post(s)
    You DON'T want to be in the High Country with a car that jumps out of gear. Could be deadly.
  13. #19
    A friend of mine uses red line oil in his TD4.2 and service intervals are now every 100k
    with filter change and oil top up every 10k
  14. #20
    Feb 2014
    Canberra
    That's the sort of info I was getting before trying it. I used Liqui Moly before and didn't experience any real difference to performance from the oils I was using prior to that. I guess time will tell.
    Hoping to upload some photos and introduce the ute this weekend.
