Results 1 to 10 of 11
Thread: Dull thud noise
    Expert Rickie3's Avatar
    Jan 2014
    Dull thud noise
    my 2000 GU 3 litre makes a horrible dull thudding sound when first starting and switching engine off, the noise is also audible when driving and hitting slight bumps, could it be a broken engine mount? what is the best way to test if broken? ive tried with the engine running 1st and reverse to see if the engine lifts but the engine hardly moves any other pointers?
    Under hard acceleration and deacceleration does the gear stick move sideways much??
  3. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Rickie3 (27th February 2014)
    Jan 2014
    havent noticed but will check that out shortly
    Jan 2014
    if you get under the car with a crow bar or some sort of leaver slide it under something solid and try to lift the engine if the mount separate there stuffed
  6. The Following User Says Thank You to Tomdinneen For This Useful Post:
    Rickie3 (26th February 2014)
    Patrol God Stropp's Avatar
    38 Post(s)
    i would say engine mounts.
  8. The Following User Says Thank You to Stropp For This Useful Post:
  9. #6
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    Before you get into the expense of engine mounts, I'd say that you should check all the exhaust mounting points. If one's broken then when you go over a speed bump or something, then the exhaust can hit the chassis and it makes horrible dull thuds. Also on start up and shut down.
    Steve
    2011 Patrol Safari 4.8 (Fitek)
  10. The Following 2 Users Say Thank You to Bulbous For This Useful Post:
    BigRAWesty (27th February 2014), Rickie3 (27th February 2014)
  11. #7
    Jan 2014
    Ok chaps after an exhausting day trying to find this damn dull thudding noise, I tried all engine mounts, gearbox mounts with a pinch bar and none were broken and appeared to be in excellent order, so I checked exhaust system and all mounting that appeared fine, anyway I sang out to my son to bounce up and down on the bullbar, well bugger me there was that horrid thumping sound, I ended up located the problem, the chassis mounts at the front under the radiator support are ratshit, anyway just to get me out of trouble I cut some thick rubber washers and forced into the gap, now to add injury to insultthe bloody bolt on the right side snapped so looks like fun and games drilling that sucker out, anyway my question is? in order to replace the front chassis rubbers do I need to loosen all the cab mounts? and wheres the best place to buy these new bushes?
  12. #8
    Legendary happygu's Avatar
    Good find Rickie,
    Cant comment with authority on the changing over of the body mounts, but I would think you could try loosening the front mounts a little, and try levering a gap with which to remove and replace the mounts.
    You could try Patrolapart, Ebay or Nissan, for the parts.
    Mic
  13. The Following User Says Thank You to happygu For This Useful Post:
    Rickie3 (2nd March 2014)
  14. #9
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    You will need to loosen all the mounts because it requires the body to be lifted about an inch just to remove the mount and install the new. Stick with genuine mounts, atoc I think has the best prices. Don't go to nissan to buy them, you will die at their prices. Sounds like a difficult job but it's not that bad. Only need to lift one side of the car at a time, not the whole thing.
  15. The Following User Says Thank You to Parksy For This Useful Post:
    Rickie3 (3rd March 2014)
  16. #10
    Jan 2014
    Thumbs up
    Ok decided to hook in and replace those worn front chassis mounts today, bought new nolothane bushes got them at trade price $90 the pair, anyway decided to start on the right side and had to try and get out that snapped bolt so loosened all body mount bolts and jacked her up, got the old mount out fine, so I gathered up a old wheel nut and welded onto where the bolt had snapped all went ok then the bolt snapped again so I was in the shit big time and there was no way of drilling out as there was a fair amount of bolt left in there, so I removed my bullbar and had to make a cut where the chassis bolt was located that went well, managed to cold chissel the bugger out and I bought a new bolt and nut,installed bush and re-welded my cuts and covered the welds and plate with sound deadner, all up took me 3 hours to replace both mounts and re-install the bullbar, but well worth the effort my bus is fantastic on the road now and no more horrible thuds
