Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Loosely mechanical - f/l light wiper leaks
    Oct 2011
    Thanks Bazz, I kindof like the idea of being able clean the lights after that next big bog, hopefully they will be behind a bush bar (if I can spring the funds from home command...)
    Did you have any problems with your leaking or were they gone before you found out?
    Dave
  2. #12
    Oct 2011
    Smile
    Right, an update.
    Went to Nissan and ID'd the part. After the heart attack ($40 and from Japan) went and got the part from the local Nissan Wreckers (NISCars, Lower Hutt) for free (I brought some other stuff as well).
    Diagram and part numbers attached.
    A thimble sized valve.
    Managed to get it in place and it seems to be holding!
    Biggest hurdle was getting my hands in to put the valve in place, then getting the front grill back in place.
    Thanks for the assist team.
    Next challenge, replacing the L/wing mirror with a Y60 Kingsroad version (5pin with defroster)
  3. #13
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    $40 for a little piece of plastic with a spring and ball inside??? geez Nissan doesn't miss you.
    I noticed in the picture they call it a valve check.
    Glad you got it sorted.
    Cheers Rodney
  4. #14
    Advanced kibitz's Avatar
    Jan 2014
    Sibiu, Romania
    Hi,
    I found this code (289380Y700 for the same part) here (look a position 9).
    Sorin
    aka Sorin
    [__]\≡≡≡\≡Ө≡/≡≡≡/__] Patrol Y61 2.8 SWB
