Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 111
Thread: Fuel range GU 2010
  1. #61
    Western suburbs of Melbourne
    12 Post(s)
    Yep I'm around 700 k's for 148 ltr tank but not sure how much is left in the tank when the light comes on I will have to check how much goes in next time.
    Wow that's 21 plus litres per hundred.
  2. #62
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    I've been getting around 16.5-18.5ltrs per 100km. I've got 2" lift, rear bar, steel bullbar, steel roof rack, draws, second battery, 12000 lbs winch with steel cable and 33" bighorns
    Edit: should mention I've got a steinbauer chip and manta 3" exhaust
  3. #63
    Expert oddkid82's Avatar
    Apr 2013
    Those k's and Ltrs is 13.33L/100
    That makes does make sense I never put in 120lt of when I fill up I usually have about 5 to 10lt left in the tank which will make it at 12L/100 kms.
    I am still pretty happy with that,
  4. #64
    that's probably good if you seen the way he drives.
  5. The Following User Says Thank You to Avo For This Useful Post:
    Stropp (21st February 2014)
  6. #65
    Quote Originally Posted by wa 489 View Post
    Foot to the floor screaming around in 1st gear lol
  7. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Avo (20th February 2014), Stropp (21st February 2014)
  8. #66
    figured out I'm getting 16.5 lt per 100km,going to try a few things we'll see how long it lasts.clean a few things measure again.then try and drive so rpm doesn't go much more than 2500rpm,also trying to drive around at 100km/h
  9. #67
    Legendary happygu's Avatar
    I just drive mine normally without worrying too much about revs, and I am in the 13 - 13.5 range.
    I keep the tyres around 38 Psi, and always fill up with BP Diesel.
    MIc
  10. #68
    Patrol God Stropp's Avatar
    38 Post(s)
    I just drive normally to
  11. #69
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Was having a look at my past fuel records. Most of which are highway figures.
    Towing a 16ft poptop caravan: 16.46 to 18.51 L/100
    Not towing: 11.61 to 13.69 L/100.
    I drive quite easy.
    Edit my trip meter is very close to what the Gps reads)
    Was a CRD
  12. #70
    Wow these are quite high..
    I'm getting 14.5 out of my na brick. That's combined highway and town..
