Results 1 to 10 of 17
Thread: Dirty MAF sensor and intercooler leak
Threaded View
  1. #6
    Expert HV2002's Avatar
    Jan 2014
    Camden South NSW
    Hi Patrol-Guy I’m not Shaw if removing the sensor will register a fault but after reading Tony's guide he did say (later in the thread, as an afterthought) you should disconnect the battery
    Tony’s thread …. http://www.nissanpatrol.com.au/forum...ng-MAF-sensors
    I also read some were that if you only disconnect the negative terminal you won’t lose your odometer reading …. Don’t know if this is true or not as I only remembered it after I had finished
    Lemo the tape is only a quick fix. if you haven't rubbed through the cor yet it would be better to put a spacer under the cover and stop it placing pressure on the ribs
  2. The Following User Says Thank You to HV2002 For This Useful Post:
    Patrol-Guy (18th February 2014)
