Results 1 to 9 of 9
Thread: Speedometer light is not working
    Feb 2014
    Exclamation Speedometer light is not working
    my speedometer light is not working. how do I fix this? I have tried to remove the seethru panel in front of it but the steering wheel seems to be in the way.
  2. The Following User Says Thank You to mumblesmac For This Useful Post:
    PMC (16th February 2014)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi mate, I have moved this out of the intro thread and into the auto electrical thread.
    Although its not mandatory how about heading back to the intro section and telling us a bit about yourself and your rig
    Toddie
    Patrol Guru
    Apr 2011
    Melton
    What truck - model?
    On the GQ you remove the cluster - flip and you can acess the lights from behind
    Feb 2014
    2003 GU 3. Patrol 3L diesel.
    Legendary happygu's Avatar
    I haven't tried Mac, but you can try removing the lower kick panel under the steering column, to see if you can shine a torch in and reach the back of the instrument cluster.
    I don't think you can, and I think you actually need to unscrew the plastic panels surrounding the cluster itself, and remove the cluster from the vehicle. After all that it is easy, as the globes are in a little twist-in globe holder.
    Try not to touch the Glowing end of the globes with your fingers if you can - hold it with a rag so it doesn't get any oils from your fingers on it. It should be OK, as it isn't high heat, but this can cause some halogen globes to blow, so don't take the risk, as it is too hard to pull out twice....
    Mic
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Is it just the speedo light or has the light gone behind all the other gauges as well (tacho, fuel and temp)?
    It might be a faulty dash light dimmer switch.
    Feb 2014
    Just the speedo light, all others working ok, thanks.
    Hardcore
    Coffs Harbour
    Quote Originally Posted by mumblesmac View Post
    G’day mumblesmac,
    Welcome aboard mate! I hope you enjoy your stay with this great forum and its members!
    PS, Shite-loads of info and good laughs to be had all-round!
    Regards,
    RLI
    The halls been rented the bands been paid, time to see you dance!
  10. #9
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    My speedo light went aswell. To make it easier I unbolted the steering wheel bracket from underneath and the whole assembely lowered out of the way so I could get the cluster out. I changed mine to LED blue color which look great
  11. The Following User Says Thank You to meh For This Useful Post:
    mumblesmac (17th February 2014)
