Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 111
Thread: Fuel range GU 2010
  1. #31
    Legendary happygu's Avatar
    Quote Originally Posted by 93patrol View Post
    i have a mate with a standard 2009 gu auto and he cleans his MAF once a month and gets the best economy out of it then when he doesn't clean it regulary it uses more diesel.
    Fry was saying that if his boost goes over 8PSI his economy goes down hill but i can't remember fully what he said but his is also manual
    93Patrol,
    It seems a little excessive cleaning the Maf every month ..... I have never ever cleaned mine on 4 different Patrols - with heaps of k's too.
    Unless he is doing heaps of k's, I think it would be more costly to clean the Maf every month, then pay for the extra fuel used
    Mic
  2. #32
    Quote Originally Posted by wa 489 View Post
    decided to finish this tank through it then do the MAF clean and see if recognise the difference,fuel light come on at 473km,put transfer pump on run that through then clean it.
    got the torx bit thanks,best thing about living opposite the workshop.
    Sweet... don't forget to look into getting a Scan gauge or one of it's clones
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    Avo (16th February 2014)
  4. #33
    177 Post(s)
    Hey evil, can you point us to a proper scan gauge mate. Just looking at eBay and there is various ones on there.
  5. The Following User Says Thank You to Hodge For This Useful Post:
  6. #34
    Advanced Fry's Avatar
    Sep 2013
    WA
    "For example, if you killed your grandfather, you'd cease to exist!"
    ―Professor Farnsworth
    "But existing is basically all I do!"
    ―Fry
  7. The Following User Says Thank You to Fry For This Useful Post:
  8. #35
    Advanced critta11's Avatar
    Feb 2014
    Quote Originally Posted by happygtu View Post
    93Patrol,
    Mic
    If your living on dirt roads as I do or do a lot of off-road driving it's recommended to clean the maff every service. It's a very easy thing to do and only takes 5mins.
  9. #36
    177 Post(s)
    Quote Originally Posted by Fry View Post
    Thanks for that mate. Scangauge ordered.
  10. #37
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by critta11 View Post
    I thought these sensors are self cleaning where (after switch off or on switch on) they glow red hot to burn off any crap on the wire...I could be wrong but I suppose its still a good idea to clean them every now and again to make sure. Mine is 2 years old and never cleaned...LOL maybe I should give it a quick spray.
    ________________________
    ______ 2017 D-Max _______
  11. #38
    Feb 2014
    They could but I haven't heard of that. If you don't have a catch can you'll be surprised with the amount of oil and gunk on them even when they look clean. Use CO contact cleaner that leaves no residue or a maff sensor cleaner and spray it over a White cloth till it runs clear. Mine hadn't been cleaned for it's lifetime (180,000) and was working fine (what I thought was fine) till it stopped functioning properly and car was driving like sh!#. Cleaned it but it was past that. Bought a new one and drove like new! So if you clean them regularly I assume they won't burn out.
    Also I've heard you should unhook the battery for around 10mins to reset the computer but I'm not sure how much that changes things.
  12. #39
    Thanks Critta,
    I didn't know that, and haven't seen that in the service book.
    Mine gets done by Nissan, and I wonder if Nissan actually do that at the service.....
    Mic
  13. #40
    177 Post(s)
    I doubt it. They don't have enough volts running through them to do that. I bought a new one from mudski a while back and replaced my old one which was pretty dirty. Pretty sure I posted a photo of the compared pair somewhere on here. New one I've cleaned every oil change. If you spray it above a clean white paper, you will see how much s*** comes out of it. I think even a tiny coat of crap over the sensor can affect the voltages send to the ECU, which in turn could affect your performance.
