Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 151
Thread: MYSTERY ISSUE. Doing my head in. Please Help!
  1. #81
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by Evo View Post
    Ok,
    So after the fancy diagnosing session, which cost $77, the issue has been somewhat narrowed down.
    The mechanic recommended I get my engine mounts replaced as they are in need of it, as he said it seems to be the plating either side of the rubber (where the plates are bent to hook into each other) as there is basically no clearance here due to the rubber having collapsed a lot.
    If there is still an issue, he recommends clutch next, and has told me that rest of driveline is good.
    After hearing all this, I'm still not sure whether to believe what I'm told, but engine mounts are a cheap start, so fingers crossed.
    And I'll need a clutch later anyhow, I have known this since last year, but the longer I can put it off, the better.
    Plus I'll get onto the auto-manual hub conversion over the weekend hopefully.
    With the locking hubs, I was going to use some medium strength loctite on the cap head bolts. Is this ok or what do you guys recommend?
    Evo
    $77.00 sounds a good price for a test like that, hope you are onto it now.
    Macca
  2. #82
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    Yeah, saves thousands in repairing things that might be fine.
    Going to get engine mounts done as they need it anyway, and do the free wheeling hubs, then see how things go.
    Evo
    Cheers,
    Evo
  3. The Following User Says Thank You to Evo For This Useful Post:
    Stropp (13th February 2014)
  4. #83
    84 Post(s)
    I was trying to find a thread on replacement hubs. I think the advise was to get Nissan Hubs, but don't me quote on that.
  5. #84
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    My advice is don't so engine mounts and hubs at the same time. Take a spin after doing one, then do the other. This way, if the problem is fixed, you know the solution.
  6. The Following 2 Users Say Thank You to Parksy For This Useful Post:
    Evo (12th February 2014), mudnut (12th February 2014)
  7. #85
    Jun 2013
    I think that's what these ones are.
    Had a look at the AVM hubs, but they looked a bit too complicated and too many parts.
    Quote Originally Posted by Parksy View Post
    I probably didn't mention it clearly, my bad, but mounts are tomorrow, hubs over weekend.
    I'm not too fussed about the hubs, but fingers crossed for tomorrow.
    Evo
    Cheers,
    Evo
  8. The Following User Says Thank You to Evo For This Useful Post:
  9. #86
    Evo
    are you getting the engine mounts done for you? Also are you doing the transmission mounts too?
  10. #87
    Jun 2013
    Yeah, getting the engine mounts done for me.
    Only engine mounts. Trans mounts checked out ok, but can only afford to do the engine ones at the moment.
    If I can scrape enough together, I'll more than likely get new trans mounts when the clutch gets done.
    Evo
    Cheers,
    Evo
  11. The Following User Says Thank You to Evo For This Useful Post:
  12. #88
    Evo
    good stuff, I only ask because I found the engine mounts a prick of a job to do.......... so much so, I still havent done the drivers side yet lol
  13. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Evo (13th February 2014), Stropp (13th February 2014)
  14. #89
    Jun 2013
    Fair call.
    Definitely going to save me more grief then. lol
    Evo
    Cheers,
    Evo
  15. #90
    Patrol God Stropp's Avatar
    38 Post(s)
    Well done on persevering with the problem evo, let's hope the engine mounts sort the problem.
