Results 11 to 20 of 23
Thread: Best rock sliders
    Perth WA
    63 Post(s)
    XLR8 Fabrications in Perth make the best sliders around.
    http://www.xlr8fabrications.com/
  2. The Following 3 Users Say Thank You to Woof For This Useful Post:
    93patrol (9th February 2014), Bigcol (18th June 2016), megatexture (9th February 2014)
  3. #12
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Definately solid. XLR8 makes them strong. I think the car will fall apart before the sliders get damaged
  4. #13
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    If you have a, or access to a welder, make your own! I did and made a solid slider but stuck it out a bit further to use as a side step aswell. also helps keep your car off the rock/ bank/ stump etc. 50 mm internal diameter 3mm wall.
    GQ Snorkle Lockers front n rear
  5. #14
    brisbane
    Quote Originally Posted by 89gqpatrol4x4 View Post
    I wouldn't trust my welding enough for how strong I want it and don't have a pipe bender.
  6. #15
    brisbane
    Quote Originally Posted by pickers View Post
    Raaslar do a nice slider with brush bar for about a $1000
    But I think you need to remove the lower back gaurd which I am not that keen on.
    I think the plastic bit you are referring to has Long been ripped off, I'm not sure why nissan put them on in the first place lol
  7. #16
    Brassall
    I only tacked mine and got someone who can weld to do it properly! I also bought bends as the pipe bender wouldn't get them tight enough for me. Just did exactly the same with my rear bar.
  8. The Following User Says Thank You to 89gqpatrol4x4 For This Useful Post:
  9. #17
    brisbane
    Quote Originally Posted by lhurley View Post
    Mine are bolsys ones. Very solid. Hes out at Ipswich. I have dropped mine hard on them a couple times with no damage other then some paint off the slider.
    I dont know of any real sliders that come with brush bars but bolsys does general fab as well so i guess he could make some up??
    I can grab a couple picks of them if you like
    If you could that would be great
  10. #18
    22 Post(s)
    There is a bloke in Gympie, Barworx 4x4, he does sliders with front and rear scrub bars
    96 GQ coil/Cab
    08 G6eT
  11. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    megatexture (10th February 2014)
  12. #19
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Bolsys.com.au
    Really nice bloke. Pretty good prices.
    I put the grip tape on, it's awesome for getting in the car when the sliders are wet, cause they are slippery as all hell, but it's a pain in the arrrs when getting out. If you slide out and graze your leg on it, it will make you bleed. You do get used to it tho.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  13. #20
    Patrol Freak gaddy's Avatar
    redlands
    After Saturday the wife has agreed that we are in the market for a set as well ! One of my mates sons made his for his 80 series and work well , best bit is he owes favour !
