Results 1 to 10 of 11
Thread: Installing anderson plug.
    Nov 2011
    REDLAND BAY.BRISBANE
    Hi guys,
    do we have a detailed thread on here for DIY anderson plug installation. i know its probably pretty simple but just wondering where people were running the wires etc....and tips
    Did a quick search but no luck.
    2008 GU WAGON , ARB DELUXE BULL BAR, CHIP AND 3" EXHAUST,SPOTTIES,ROOF RACK,SIDE AWNING
    20131227_105603.jpgI ran mine from the AUX battery to the bulbar via a 30 amp circuit breaker.
  3. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Choicebro (5th February 2014), MEGOMONSTER (8th February 2014)
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
  5. The Following 2 Users Say Thank You to Bob For This Useful Post:
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Quote Originally Posted by Choicebro View Post
    Hi guys,
    Where do you need it to be?
    I ran one to the rear of my vehicle for the trailer, and another into my cargo bay for my fridge. My trailer cabling goes out the engine bay through a grommet into the area inside the wheel arch, then inside the chassis to the back of the vehicle.
    If you are running cabling longer distances, just ensure you have sufficient cable diameter to prevent voltage drop.
  7. The Following 2 Users Say Thank You to FNQGU For This Useful Post:
    Choicebro (10th February 2014), MEGOMONSTER (8th February 2014)
  8. #5
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    as above ^^^ And put an inline fuse/breaker as close to battery as possible.
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
  9. The Following 2 Users Say Thank You to trekster For This Useful Post:
    FNQGU (9th February 2014), MEGOMONSTER (8th February 2014)
  10. #6
    Western suburbs of Melbourne
    11 Post(s)
    I too am wanting to put Anderson plug connect to my aux battery to plug my battery charger in when my car sits in the garage for a while.
    Saves me opening the bonnet.
  11. #7
    Nov 2012
    Coffs Harbour, NSW
    I got some wire from work, its 5 core 6mm lol, the outer cable is about 20mm od. I run 2 50 amp fuses about 12" off the battery, then ran this through the firewall and down the passenger side to the rear, For now I have 1 relay operating a single anderson plug for my fridge, Have a second one there and cable for it but not connected for now. When I soldered my cable into my plugs I used a gas torch to get the plug hot and soldered the wire in it and filled it with solder giving an excellent connection, once they cooled I popped them back into the case and away I went.
    1998 GU RD28T: RIP
  12. The Following User Says Thank You to trekster For This Useful Post:
  13. #8
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Yes, as per Treckster's comment about the fuse/breaker. I run a 50A Maxi fuse for my trailer cabling right at the battery end.
    Also, when soldering your Anderson Plug lugs, make sure you have them aligned with the wire and the plug BEFORE you drop them into the hot solder and they harden. If you don't you will have to twist the cabling all over the place to get them to fit in properly or do them again. Those lugs only go in properly one way. You CAN actually stick them in back to front and they will push right in, but there won't be a proper fit and connection.
  14. The Following User Says Thank You to FNQGU For This Useful Post:
  15. #9
    Advanced Mitch.mccabe's Avatar
    Aug 2013
    Lightning Ridge, NSW
    Hey you guys seen or used the single into double/Triple Anderson plugs on ebay? http://www.ebay.com.au/itm/ANDERSON-...item3383b5c5bb They look ok for the price?
    GU Series 07/2013 Y61 Patrol -Bullbar and Spotties, Side Steps, 5 Speed Man, Newly added ARB Alloy Roof Cage, Snorkel
  16. #10
    475 Post(s)
    Geez at that price why would you bother making it.
  17. The Following User Says Thank You to mudski For This Useful Post:
    Mitch.mccabe (27th February 2014)
