Results 11 to 20 of 29
Thread: 33 on back barn door
    Nah they fit alright
    I wonder why Kaymar went to all the trouble making a bracket If the fit alright
    40mm out and 60mm up from memory.
    but its not about 35 is it
  2. #12
    Probably not a good idea to have that much weight on the rear door.
  3. #13
    Hardcore
    Coffs Harbour
    Quote Originally Posted by ThomasWatson View Post
    Does a 33 fit on the back door?
    G'day ThomasWatson,
    I have a 285/75R16 Dick Cepek FC-II on a 2001 GU Patrol, on the original rim and it fits ok, however, you need to adjust the bracket on the door, (remove the wheel and look internally to where the bracket bolts to the door, undo and remove the 4 x 17mm nuts and lift the bracket up to the next bolt patten, this allows the 33 to fit without rubbing on the bar!)
    PS, MudRunner notice when i was down in Victoria at Christmas that my Tyre was rubbing on the bar and not allowing the door to shut properly and advised me how to fix it.
    Regards,
    RLI
    The halls been rented the bands been paid, time to see you dance!
  4. The Following User Says Thank You to PMC For This Useful Post:
    growler2058 (6th February 2014)
  5. #14
    Expert ThomasWatson's Avatar
    Jan 2014
    Sydney NSW
    Quote Originally Posted by RLI View Post
    G'day ThomasWatson,
    Regards,
    RLI
    Exact same size I'm fitting but different brand I can get 285/75R16 kumho kl71 for 250 a tyre is that a relatively good tyre?
  6. The Following User Says Thank You to ThomasWatson For This Useful Post:
    PMC (6th February 2014)
  7. #15
    Jan 2014
    Sydney NSW
    Also do I have to remove my mud flaps to fit the tyres
  8. The Following User Says Thank You to ThomasWatson For This Useful Post:
  9. #16
    Western suburbs of Melbourne
    12 Post(s)
    I removed the front flaps, I had about a 10mm gap between tyre and flap on a locked wheel.
  10. #17
    Hardcore
    Coffs Harbour
    G'evening ThomasWatson,
    On the GU 4.2 turbo diesel wagons from 1999 to 2006 they will fit OK.There is plenty of room under there if you have a 2inch lift.
    PS, however, I do not know about the 3lt Patrols.
    Regards,
    RLI
  11. #18
    Jan 2014
    Sydney NSW
    Regards,
    RLI
    I'm getting a 3" lift from suspensions tuff.com
    Just wanted to know whether I can keep my front mudflaps lol
  12. #19
    Hardcore
    Coffs Harbour
    G'day mate,
    I did not have to remove my mudflaps, my Patrol is 2001 GU 4.2 turbo diesel wagon, as previously advised i do not know if the same applies for the 3lt Patrols.
    Regards,
    RLI
  13. #20
    G'day mate,
    Regards,
    RLI
    Would've thought they'd be the same
