Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: 33 on back barn door
    Expert ThomasWatson's Avatar
    Jan 2014
    Sydney NSW
    Does a 33 fit on the back door?
  2. The Following User Says Thank You to ThomasWatson For This Useful Post:
    PMC (6th February 2014)
    Legendary Alitis007's Avatar
    15 Post(s)
    My 33's fit on my barn but it depends what offset your rims for eg the factory rims with a +10 offset sits close to the door but the steel rims with my 33's have a -13 offset have alot more room.
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    x2 with Alitis007. I have same set up. Just remember the extra weight. That also concerns me, when the dollars permit I will replace rear bar and mount off there.
  5. The Following User Says Thank You to Steve4wdin For This Useful Post:
    Alitis007 (6th February 2014)
    33" should fit if not buy longer 10mm x 1.25 pitch bolts say 50 mm long
    and space the rear wheel bracket out with some washers.
    I mounted mine internally as its a lot of weight on the door
    growler2058 (6th February 2014)
  8. #5
    Thomastown, Melbourne
    6 Post(s)
    I have a spacer for my light set up and have more than enough room for 35.. I would not put a 35 on though due to weight!!
  9. #6
    Always thought you need to come out and up to fit
    a 35 but remembered you have a custom rear bar
    STD I think you will struggle to fit a 35 on a GQ, but
    that's not the OP
  10. #7
    Western suburbs of Melbourne
    12 Post(s)
    On my GU8 I fit a 305/70R16 BFG KM2 on the rear door with a negative 13 rim otherwise doesn't fit.
    Stretch has a 285/70R17 Dick Cepek FC-II on a GU7 on the original rim but had to put a spacer for it to fit.
    I think it was touching the wiper or the actual barn door or both.
  11. #8
    @ Mego if you want I have some laser cut disc 12mm you can fit up behind the rear wheel bracket.
  12. #9
    Nah they fit alright
  13. #10
    12 Post(s)
    Thanks anyway, his neighbour machined something up for him already.
