Results 1 to 10 of 14
Thread: Fuel Drain Plug Leaking Still - AAAAARRRRRRGGGGGHHHHH
    Beginner OlTroll's Avatar
    Jul 2013
    Cockatoo Victoria
    Unhappy Fuel Drain Plug Leaking Still - AAAAARRRRRRGGGGGHHHHH
    Hi guys,
    wondering if anyone has this problem and/or knows how to fix it, leaking drain plug on my LWB wagon diesel tank.
    Nissan manual simply says "packing material" and does not give me a washer type.
    What type of washer if any?
    Anything I can use on the plug threads to help get a seal (ARF ARF)
    Dang, i'm annoyed.
    OlTroll
    you would use an annealed copper washer wouldn't you.
    like a squash washer, or heaps of Teflon tape until you get a proper washer
  3. The Following User Says Thank You to threedogs For This Useful Post:
    OlTroll (4th February 2014)
    Jul 2013
    Cockatoo Victoria
    I thought copper, but before I go draining my tank again, was looking for info. Maybe teflon and copper until it leaks, might get a few years, love more feedback
    Jul 2013
    Cockatoo Victoria
    Anyone have an actual answer? Love to get this sorted for once and for all!
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    I can't see why the copper washer and Teflon wouldn't work
    Sorry that it's not an actual answer
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
    Yep I used a copper washer and Teflon tape. I assume you mean the drain on the bottom of the tank?
    Dowdy washer . It's like a washer with a rubber seal bonded to it.
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    OlTroll (6th February 2014)
  10. #8
    Oct 2010
    Old Bar, NSW
    A copper washer is what is on the engine sump plug, wouldn't that work on a fuel tank?
    Are the surfaces of the tank and plug flat and undamaged?
    Are you sure the thread or weld around the drain is not cracked? Your leak might be from somewhere else.
    Macca
  11. #9
    Hey come to think of it! You are right Newby,I think mine have a rubber ring in it, only had it out once for other reasons.
    Are you sure the thread or weld around the sump is not cracked? Your leak might be from somewhere else.
    Yes as Newby stated the washer is as he described. Also Teflon Tape is a winner for me.
  12. #10
    Jul 2013
    If telon tape doesn't work there is a thread sealing compound you can get from supercheap had to use it once on a banjo bolt for a turbo oil line once . As I couldn't get a good seal with the copper washers
    Some times depending on the material steel or alloy the threads can stretch
