Results 11 to 20 of 21
Thread: Drop boxes or caster bushes
    Expert @GUte's Avatar
    Aug 2013
    Beechworth, Nth East Vic
    "Effectively they are designed to achieve that flat radius arm from the factory mount by increasing the drop of the front half of the arm."
    MR, they will still retain the same geometry as factory arms with correction bushes regardless of how you design the arm. You have to drop the rear. The main benefit of those arms is that you retain the OEM bush.
    http://www.superiorengineering.com.a...ducts_id=19954
    These arms that use the drop box help keep the line to factory depending on lift.
    http://www.superiorengineering.com.a...ducts_id=20308
    Al.
  2. The Following User Says Thank You to @GUte For This Useful Post:
    PMC (28th January 2014)
  3. #12
    Thomastown, Melbourne
    6 Post(s)
    So B rad did you get your answer you were after???????
    I will be saving for drop boxes for many reasons already covered... I feel the best option for me.. I will thank you guys for your input!!!
  4. #13
    brisbane
    Quote Originally Posted by @GUte View Post
    Al.
    These would be the go getting rid of the stock chassis bushes for a more suited less restrictive bush but alot more coin if your on a budget
  5. #14
    Sep 2013
    Wollongong NSW
    Do you need to worry about this if all you want is a 2" lift?
  6. #15
    Aug 2013
    Quote Originally Posted by megatexture View Post
    Yeah they are the go.
    Quote Originally Posted by 4WD DUDE View Post
    Occasionally some vehicles don't need caster correction. If you need correction, your best going the drop box route.
  7. The Following User Says Thank You to @GUte For This Useful Post:
  8. #16
    Oct 2011
    Essendon
    So someone (can't remember who) mentioned earlier in this thread that there was some question on the "legality" of drop boxes.
    Thoughts, comments from those qualified?
  9. #17
    Quote Originally Posted by Drewboyaus View Post
    Illegal unless engineered.. It's a chassis and suspension mod outside of the legal acceptable changes made by law..
    But there sorta like light bars. People take the risk as its not a huge thing to change back..
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Drewboyaus (7th November 2013)
  11. #18
    How's the serenity boots's Avatar
    Sep 2011
    No not necessary
  12. #19
    Hardcore
    central coast nsw
    Quote Originally Posted by boots View Post
    No not necessary
    I disagree, our Mav simply had to have correction.
    Steering in the wet was totally dangerous without correction.
    Oversteer was very evident even in the dry.
    Every vehicle is different, get an alignment report printout and check off angles against std settings.
    and remedy to suit. m2cw
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  13. The Following User Says Thank You to Robo For This Useful Post:
    MEGOMONSTER (27th January 2014)
  14. #20
    Advanced DSzuke's Avatar
    Orange, NSW
    I have a question on this too...
    I am about to throw some 2" springs and shocks in mine.
    Should I go and get a check of the current castor angle so they can compare them after the lift?
    Can I expect the local Bob Jane to know the factory specs for a GU or are they somewhere in the bible here?
    2007 CRD Ti Patrol - springs, shocks, tyres, dual batt, bits of NADS here and there… (lots more to come)
