Results 1 to 10 of 13
Thread: kibitz - My car's history
    Advanced kibitz's Avatar
    Jan 2014
    Sibiu, Romania
    My car's history
    As promissed I will try to present my car's history a bit.
    The small improvements I did to my car were to put a set of 33 inch mud/terrain tires (COOPER STT), a President JFK II CB radio and a SIRIO 5000 CB antenna.
    The colleauges from Holland will notice that the car is bought from there, by looking at the plates . It is a two seater, because it was converted to a utility van before I bought it (I want it this way because the taxes are smaller in Romania).
    This is how the car looked liked when I bought it (about two years ago):
    The new tires:
    I worked a little bit to make room for the CB as it was a little bit longer than expected:
    New IronMan steering dumper:
    More to come...
  2. The Following User Says Thank You to kibitz For This Useful Post:
    NissanGQ4.2 (26th January 2014)
    Jan 2014
    Sibiu, Romania
    My car's history - roof off
    Next thing I did was to take down the roof as I intended to buy a new suspension lift kit and the car wouldn't fit anymore in my garrage.
    The roof for the utility vans is modified (I believe because they must have a certain load capacity). The modification consists of installing a fiberglass roof on top of the existing one, which is cut to make more room.
    I started by dissasembilng the side panels for rear windows:
    I dissasembled then the roof light support, the temperature and heading indicator from the front of the roof, the rearwivew mirror and other small things that were attached to the roof. I coud then take down the roof lining/cover (hope this makes sense - my english is not so good especially with technical terms).
    Thext on the list was the roof window (it is a bit heavy 10-12 Kilos):
    Next part was a little bit hard to persuade to come off as it was glued vey well to/through the original roof (fitted throgugh the hole):
    Here it is how it looked like after taking it down:
    Next step was to take down the external fiberglass roof; it was relatively easy to cut. Unfortunatelly I have no pictures with that operation.
    I bought a piece of the metal rooftop from some guy who disassembles old/crashed cars and weld it over the hole in the original roof.
    To be continued...
    aka Sorin
    [__]\≡≡≡\≡Ө≡/≡≡≡/__] Patrol Y61 2.8 SWB
  4. The Following User Says Thank You to kibitz For This Useful Post:
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Looks good Sorin
    Wow good stuff Sorin keep them coming
    Western suburbs of Melbourne
    11 Post(s)
    There must be a heap of these shorty's over in Europe.
    They look great.
    Jan 2014
    South of Adelaide
    Bună Ziua Sorin,
    Looking good with the build.
    Perfect vehicle for Romanina.
    Jan 2014
    Sibiu, Romania
    Hi,
    @threedogs: Thank you!
    @MEGOMONSTER: Indeed there are quite a few . As moneypit mentioned, these are perfect for Romania. For both on- and off- road (as some of the streets here are bad). For off-road it has the advantage that it can take tight turns.
    @moneypit: Multumesc! Cum de stii romaneste? Ai plecat acolo sau ai rude/prieteni aici? (Translation for the rest of the forum members: Thank you! How come you know to speak romanian? Have you gone there [Adelaide] or do you have relatives/friends here?)
    Cheers,
    Sorin
    aka Sorin
  10. The Following User Says Thank You to kibitz For This Useful Post:
    MEGOMONSTER (27th January 2014)
  11. #8
    Jan 2014
    South of Adelaide
    Hi Sorin,
    Worked in Romania for 18 months in the Oil and Gas industry so managed to pick up a bit of the lingo. Unfortunately most people couldn't understand the Aussie accent, one of the guys i worked with could understand a Scottish accent better than mine
  12. #9
    Jan 2014
    Sibiu, Romania
    Quote Originally Posted by moneypit View Post
    Hi Sorin,
    Oh, ok. It makes sense.
    18 months? It's quite a long time, but I guess is common in your line of work.
    How did you like it here?
    aka Sorin
  13. #10
    Jul 2013
    I wish the shortys were deliverd here in aus
