Page 6 of 17 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 170
Thread: DIESEL FUEL + 2T OIL = Superb performance?
  1. #51
    Beginner Dave_GU_ACT's Avatar
    Jan 2014
    Just to reignite this age old debate, 2t Self mix according to the MSDS is a mineral based additive. I have extracted a little info from that document. im about to put it in my GUIII 3.0l DI.
    Material Safety Data Sheet
    1 .
    Identification of the material and supplier
    Castrol 2T Selfmix
    Product name
    462220
    SDS no.
    Product use
    Lubricant for two-stroke engines.
    For specific application advice see appropriate Technical Data Sheet or consult our company
    representative.
    BP Australia Pty Ltd (ABN 53 004 085 616)
    717 Bourke Street
    Docklands VIC 3008
    Australia
    Tel: +61 (03) 9268 4111
    Fax: +61 (03) 9268 3321
    Supplier
    +61 2801 44558 (or 1800 14 14 74 within Australia)
    EMERGENCY TELEPHONE
    NUMBER
    Product code
    462220-AU07
    Hazards identification
    2 .
    NON-HAZARDOUS SUBSTANCE. NON-DANGEROUS GOODS.
    Statement of
    hazardous/dangerous nature
    Composition/information on ingredients
    3 .
    Highly refined base oil (IP 346 DMSO extract < 3%). Proprietary performance additives.
    This product does not contain any hazardous ingredients at or above regulated thresholds
  2. #52
    anyone have a picture of the bottle. or do I just ask for 2T additive
  3. #53
    Castrol do a 2T In a white 1ltr bottle, square with castrol green label.
    Used this stuff with Rc planes.
    Imo the little which is being added (20mL/ tank) would be doing fark all..
    I tried black diesel a while back. I started with a 1/10 ratio, and apart from being very messy and a little more smoke when I hit 50/50, it made everything as quite as a mouse.
    So imho to see the benefits of this added lubrication I think quantities need to be of around the 1\10 ratio. But then it becomes to bloody expensive
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    threedogs (22nd January 2014)
  5. #54
    I take it you use this in the fuel as an additive
  6. #55
    Nov 2013
    Gold Coast
    How would TCW-3 go ie outboard 2 stroke oil. Its the cheap mineral stuff, works fine in the boat motors so as an additive in a 4.2 T could there be any issues?
  7. #56
    I personally don't, fuels these days are made to get max bang for buck and have lube additives already in them..
    Quote Originally Posted by Chimo View Post
    Not sure mate. Jump on Google and look for a tcw3 msds. Have a read threw it to see if it has any nasty properties, check the area under Fire. Properties do change once change from solid to gas..
    Nov 2013
    Tangambalanga
    Before i saw the light and bought a Patrol, i drove a Landrover Defender 300 Tdi. The poms have been doing this for years. My Defender has done 360,000 kms of which half of this i have used 2 stroke oil in the diesel. The motor runs brilliant.
    Uses no oil.
    I have also heard, but not tried, filtering your old sump oil and using it instead of 2 stroke.
    Search landyzone.uk there is heaps of information on the subject.
  9. #58
    Quote Originally Posted by gramgramfirey View Post
    Uses no oil.
    Black diesel
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    I tried yesterday. Mannol 2t Universal.
    Didn't see anything unusual yet. May be more than 1 to 200?
    Brother's Pajero became work a little bit smoother.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
  11. #60
    Expert Petit caillou's Avatar
    Jul 2012
    FRANCE
    Hi,
    I also use 2T oil in the tank 250ml for 95l I found that the engine is less noisy and there is no more moke, my oil is Racing 2T and it's a full syntetic one. will tell you more about fuel economy later, but I don't thik it's the miracule priduct for fuel economy.
    Best regards
    Petit caillou.
