Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Turbo timer is it useful?
    under normal driving conditions you wouldn't get the turbo hot enough would you and a 2 min idle down would be all that's needed,
    unless you drive and get the thing glowing things might be different .
    As for MD that was the story going around, someone mentioned it on a previous thread
  2. #22
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    I have mine set at 30sec and find that is good enough for most cool downs unless like said before I have been stretching my calf muscle to get up a hill or something.
    For the wiring I tapped into the ignition perm live and the acc output to the timer and yes I also had to tap into the hand brake.
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  3. #23
    Expert ThomasWatson's Avatar
    Jan 2014
    Sydney NSW
    Quote Originally Posted by krbrooking View Post
    Which colours were they?
  4. #24
    Quote Originally Posted by ThomasWatson View Post
    Sorry mate I can't remember exactly but if you expose the wiring lume behind your ignition barrel and get a test light or multi meter. The wire that gets a reading on the multi meter/test light with nothing on is the perm live, then what you do is turn on the ignition (don't have to start the car) and the one that now gets a reading is the acc live, double check by turning the ignition off to see if it turns off.
  5. #25
    Nov 2013
    Gold Coast
    I don't know how useful or valuable a timer is except that I fitted one (1 3 or 5 minutes) when I fitted the oil cooled schwitzer in about 1990 and have not had to touch the turbo since and the 1 minute setting is always used unless I have been towing the boat (about 2.3 tonnes) and then 5 minutes is used.
    Do they work? Who knows, I would have had to fit up the same set up (GQ 4.2) without one to do a test and my injector pump specialist urged me to fit one along with an oil cooler when the turbo kit was fitted.
    How much do you save by not fitting one? How much do you need to spend if issues arise ?
    Some short term saving are just not worth it, extreme eg no condom leads to aids , cost of timer cf to turbo set up and possible repairs?
    Chimo
  6. #26
    Legendary happygu's Avatar
    Thomas,
    If you have an Auto, then by all means fit yours.
    I am not a big fan of a turbo timer in a manual, as you can't leave it in gear .... the thing is usually in a Patrol the handbrake actually works, unlike a Landcruiser ... , but still I prefer to leave it in gear.
    I just sit for a few seconds normally in the car before switching off around town, and if I am on the highway, just cruise down for the last couple of K's before stopping, and then sit for 30 seconds or so...
    Mic
  7. #27
    Nov 2013
    Gold Coast
    Echo echo !
    Chimo
  8. #28
    Jan 2014
    Sydney NSW
    Quote Originally Posted by happygtu View Post
    Thomas,
    Mic
    I have a manual and yeah the handbrake is awesome compared to my old mans Prado lol the main this first is to chip it to bring the torque up towed a little box trailer with a boat on it (tinny) and the big beast struggled
  9. #29
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    Don't know if there use full or not just put one of them plug n pray ones from arb as a mates going the ls1 route and doesn't need it so will see if its needed I usually do the same as others have posted
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
