Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: Painting Parky's GQ with a Roller
  1. #31
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Hard to say megatexture. The bonnet has been the learning curve so ofcourse it's taken longer than normal. But at a rough guess not including drying time, id say 12-15 hours over the last week maybe...
  2. #32
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    I think my advise is already late, but bottom plastic parts on doors fixed on the plastic anchors and 2 side adhesive tape. Small parts only with tape.
    I used strong steel wire to cut the tape.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
  3. The Following User Says Thank You to Wine_maker For This Useful Post:
    Parksy (21st December 2013)
  4. #33
    Jan 2013
    Nowra NSW
    5 Post(s)
    Thanks wine maker! Much appreciated!
    Another pic which shows a little orange peel, but a final wet sand and polish will turn this into glass.
  5. The Following 3 Users Say Thank You to Parksy For This Useful Post:
    growler2058 (22nd December 2013), MudRunnerTD (14th January 2014), threedogs (23rd December 2013)
  6. #34
    Jan 2013
    Nowra NSW
    5 Post(s)
    Has anyone removed the rear barn door handle/number plate light assembly? I remember once having a quick look in there but can't remember if it was an easy removal...
  7. #35
    Patrol Guru Irish's Avatar
    It's pretty straight forward to take off mate.
  8. The Following User Says Thank You to Irish For This Useful Post:
    Parksy (23rd December 2013)
  9. #36
    Jan 2013
    Nowra NSW
    5 Post(s)
    Ok, have been on holidays for the last 3 weeks and got home and carelessly gave it a buff and burnt through the paint at the same time. So I cracked the sh1ts and removed the bonnet, stripped it down and sprayed it instead.
    Edit should have added that I haven't given up, just had enough of the bonnet, what with it being such a large section and hard to reach, especially while on the car. I couldnt do the roll on method while it was unbolted and off the car as I'll need the car to drive so sprayed on was the quickest and easiest option to get it out of the way.
    Stay tuned.
  10. The Following User Says Thank You to Parksy For This Useful Post:
    BigRAWesty (14th January 2014)
  11. #37
    Quote Originally Posted by Parksy View Post
    So are you spraying the rest or going to push on rolling?
    Jan 2013
    Nowra NSW
    5 Post(s)
    Sorry westy, decided to edit at the same time.
  13. The Following User Says Thank You to Parksy For This Useful Post:
  14. #39
    Jan 2014
    Timisoara, Romania
    Nice job Parsky
    I think i will try it also on my GQ. Did anyone of you guys know how to obtain mat (not glossy) aspect on paint? it shall be the paint itself or the varnish (here i don't know if i used the correct word )
  15. #40
    Jan 2013
    Nowra NSW
    5 Post(s)
    Looking abit bare at the moment, but bonnet is back on.
  16. The Following User Says Thank You to Parksy For This Useful Post:
    Clunk (17th January 2014)
