Results 1 to 4 of 4
Thread: Rear Shelves for SWB GQ Partrol allowing back seat
    Jan 2013
    Greetings all
    I just made a set of shelves for my SWB GQ patrol. I need the back seat so this is only a short shelf. I have attached pictures and a basic parts list with the size of the pieces to build the outer frame. Cut the other parts for the inside to suit your own situation. It was all done from a single 1200 x 2400 piece of 12mm construction ply from Mr Plywood - and they cut the pieces to size for me (I only cut the ones on the inside with a hand saw). Cost was $75 for wood cut to size. I matched the paint colour by taking the little plastic screw that holds the jack compartment to the paint shop and they matched the paint colour exactly to match my vinyl. Also, to fix floor in, I used the screw holes for the two tie-down points in the back. To mark the holes, have the screw heads sticking out a bit, place the shelf system in and align, then bash floor with a rubber mallet to mark the points to drill holes. Holes align up perfectly. You need 4 x 6mm x 35mm screws and use 1 inch washers and spring washers to hold floor down (don't skimp on size of washers or the screw head could come through floor if you hit a big hole)
    As for the four shelves, I commandeered them from my daughter's bedroom to a higher calling.
    I hope this can be of help to somebody. If you have any questions, just shoot them to me.
  2. The Following 2 Users Say Thank You to angelo_f For This Useful Post:
    juzzs8 (26th November 2019), threedogs (13th January 2014)
    I'd say penny washers /mudguard washers would be perfect, great write up Btw thanks for sharing
    angelo_f (4th February 2014)
    Patrol Guru
    NT
    Thank you for the write up. I have to do something myself to go behind the third row seats.
  6. The Following User Says Thank You to P4trol For This Useful Post:
  7. #4
    Oct 2013
    Very nice and tidy, and simple too! If I get lucky enough to add a SWB to my garage soon, I will be doing something very similar to this!!
    -Piet
  8. The Following User Says Thank You to GrizzlyPiet For This Useful Post:
