Results 1 to 10 of 15
Thread: Overheating with sand driving
    Nov 2013
    QLD
    Hi everyone, I have been today out to the beach (Bribie) with my beautiful Patrol. It was the first time for me to drive 4x4 on the beach and it was awesome. Bit of driving (4H, tyres 22psi, no speeding), bit of fishing, the perfect life! After fishing, driving the car for 10km and the engine was overheating. Water in the cooling reservoir was boiling (really boiling). So I let it cool down with the bonnet open and filled up the water level (without coolant because I didnt had any). I reduced the tyre pressure even more (from 22 to 20psi) and tried to take the 25km back slowly, just in 4L (I have Nissan Patrol low range gears - 43%) and average speed of 30km. It got hot but just on the border of too hot. On the highway everything was fine and the engine was nice cool. My feeling is that it must have been a combination of factors: very soft sand, hot day, slow speed so not much wind. But I am still wondering if I should be worried (it is my first car).
    I am wondering which things are best too check. I looked at this topic http://www.nissanpatrol.com.au/forum...is-Overheating
    but I wonder if anyone else might have run into the same issues.
    If it is "really soft sand" then your tyre pressures are too high.
    I would suggest 16 to 18 PSI or lower depending on the tyre
    What year Patrol and what engine?
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    dannypatrol (12th January 2014)
    brisbane
    I'd just flush the radiator and make sure its not got mud blocking flow to start with.
  5. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    BigRAWesty (13th January 2014), dannypatrol (12th January 2014)
    Nov 2013
    QLD
    Its a 97 and 4.5l petrol/lpg. Tyres are 285/75/16
    One gauge was saying 18 psi and the other one 20 psi so I didnt want to go to low.
    Advanced Dazzalco's Avatar
    Oct 2013
    Perth
    Was it soft sand or hard sand I have gone down to about 10psi on soft sand before and all ok just don't turn to sharp otherwise roll tyre off rim
    How clean is the radiator
  8. The Following User Says Thank You to Dazzalco For This Useful Post:
    dannypatrol (13th January 2014)
  9. #6
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Big spotties will bloke a heap of air. Plus make sure your rad is clean. Pull it out and flush it, while your at it, change your hoses and thermostat. Clean rad and fresh coolant will help.
    It has been pretty hot in bris lately, make sure all your cooling components are up to scratch.
    What fuel where you running?? If you where running on gas, how recent was the gas system serviced?? A out of tune gas system will suck power out of the car needing it to work harder.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  10. #7
    Quote Originally Posted by dannypatrol View Post
    If the car runs OK elsewhere and you only had trouble on the beach...
    As mentioned by others your truck will run hotter (sometimes significantly so) on LPG depending on the tune etc.
    You need a reliable gauge as even 1 or 2 PSI on sand can make a large difference.
    I have seen, (and when teaching students to 4WD we demonstrate) that a svehicle negotiating a sand patch or dune you can't get thru on say any pressure above 16 PSI the truck will sail thru at 14 PSI.
    It can be amazing the difference a couple of pounds makes also tyres with stiff sidewalls need an even lower pressure than those with more flexible walls.
    One way to check your tyre pressure is to let the car coast to a stop and get out and check the front wheels. If the tyre is kinda "floating" on top then thats fine. If the tyre is "buried" and there is a bow wave of sand in front of it then the pressures are too high.
    If you can totally rule out your tyre pressures and driving techniques... which are free to fix... then it is time to go hunting for mechanical issues
  11. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    dannypatrol (13th January 2014), mudnut (13th January 2014), Stropp (13th January 2014)
  12. #8
    Patrol God Stropp's Avatar
    36 Post(s)
    Also if running bigger tyres (than std)it will work the engine harder
  13. The Following User Says Thank You to Stropp For This Useful Post:
  14. #9
    Good to hear you had a good day out.
    But yea, I've never had heating issues down my way.
    As mentioned tyre pressures are paramount. Invest in a decent gauge and just use the 1 so all 4 wheels are the same.
    But I'd do a little maintenance just to be sure.
    Taking the radiator out is as simple as drain fluid, remove hoses and 2 bolts. Unclip the bottom section the shroud and lift it out.
    Once out completely remove the shroud and give it all a good high pressure clean..
    're assemble and refill with good coolent.
  15. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    dannypatrol (13th January 2014), the evil twin (13th January 2014)
  16. #10
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    That's a terrible radiator you have, I'll swap my good plastic one for your bad aluminium one.....
    I've seen the radiator guys.....it's a solid built aluminium job
    1999 GU 4500 dual fuel
    Il dado è tratto
