Results 11 to 20 of 22
Thread: Toyota engine in a patrol. - easy?
    There is a thread on this conversion somewhere , he called it a NISOTA
    4.2 1hd-ft into a GU, Some dude also grafted that motor into a defender
    with GU diffs
  2. #12
    Legendary happygu's Avatar
    Here is the link for the one conversion that I know of....
    http://www.exploroz.com/Forum/Topic/....aspx%3fpn%3d2
    Mic
  3. #13
    Jan 2013
    Westys - 1hd-ft is in 80s. Mechanical. 4 valves per cylinder. Direct injection diesel. 1hd-fte is in 100s. Same engine with more standard power but computer controlled.
    Dont get me wrong, love the nissans, but toyota have always been ahead in their engines.
  4. #14
    Quote Originally Posted by Dales300exc View Post
    The 80's had a 1hdt to start with which was basically a turboed 1hz (a 1hz is no superior to a td42.) Then they went to the ft which had larger diameter crank (mains etc) to fix the bearing issue of the turboed 1hz (1hdt). Then the electronically controlled (timing only same as the later 4.2tdi) 1hd-fte, which is a nice motor but I have not seen anyone push one past the 200rwkw mark, it could be possible but I haven't seen it documented.
    The td42 on the other hand can achieve 240rwkw (around 340hp) and has been done a few times and documented. I even know a bloke running 220rwkw daily out of one.
    Yes Toyota do nice motors, they always have, but Toyota builds things like that "nice". They are great when in standard trim and will last as long as any Nissan engine, it's when the modifications start that Nissan start to come into their own. Nissan might not be as nice or as good power output wise standard but they are rugged, tough and reliable. Horses for courses though. I haven't seen any diesel ( not to say there isn't) Toyota powered vehicles competing in winch challenges/ 4wd events, (most are Nissan or v8 powered).
    As for the conversion it's been done, but would be a headache IMO.
  5. The Following 5 Users Say Thank You to nissannewby For This Useful Post:
    Dales300exc (10th January 2014), Gecko17 (12th January 2014), MudRunnerTD (10th January 2014), taslucas (10th January 2014), Wine_maker (15th January 2014)
  6. #15
    Jan 2013
    Yeh fair call. I was talking late 80s and ifs 100s.
    I dream of the day nissan put another big diesel in their patrols.
    Still building ma td anyway.
  7. #16
    Yes it would be a pearler if the cummins isv5.0 v8 turbo diesel that's going into the Nissan Titan in the states made its way into a patrol .
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #17
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Maybe you should import them newby and do engine conversions for a living. Lol
  10. #18
    Yea, Victoria
    Dont ever consider the new (reasonably) V8 Toymota diesel. There is a couple of tech's at the Toymota dealer up here working full time replacing/rebuilding them. They are making the old Nissan 3L motors look really good.
  11. #19
    177 Post(s)
    I asked this on behalf of my mate who wanted to put a V8 D4D out of a 76 series. Even though he had a perfect engine, he's done his homework and the cost / engineering costs far outweigh the cost of a fully re-built and fitted 4.2TD turbo. He's now happy as ever. The money he got for the engine covered majority of the cost for the 4.2 .
    Mind you this was in relation to a D4D V8. Some other yota engines might be easier to slot in.
    http://www.nissanpatrol.com.au/forum...D-V8-into-a-GU
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Wasn't there a guy that fitted a 1hd-fte into his Patrol , I recall it was called project TONI
    ________________________
    ______ 2017 D-Max _______
