Page 313 of 1057 FirstFirst ... 311312313314315 ... LastLast
Results 3,121 to 3,130 of 10566
  1. #3121
    Western suburbs of Melbourne
    12 Post(s)
    Quote Originally Posted by BenK View Post
    Finished rooting around with the overhead console and UHF install. Not a huge amount of storage in it, but they are certainly a good place to get the radio mounted up and out of the way.
    Pics please.
  2. #3122
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Pics please.
    Will pop a couple back in the other thread.
  3. The Following User Says Thank You to FNQGU For This Useful Post:
    MEGOMONSTER (7th January 2014)
  4. #3123
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Finished reading one of Collyn Rivers' books on camper trailers and 12V wiring and immediately shortened my Fridge cable to bring the voltage drop back to an acceptable 0.11V. I was going to change the cable to 8B&S, but shortening my currently installed 6mm Auto wire was sufficient.
    To explain - My fridge cable is 6mm auto cable (4mm2 of copper conductor), and I had 5 meters of twin flex running from the Aux battery to the fridge plug in the cargo area. This included a rolled up spare length of 2m tucked away in the rear quarter panel in case I ever changed my mind and wanted the fridge on the other side of the cargo area. My fridge cable is earthed back to the Aux battery, which effectively meant this was a 10m long circuit. By cutting off the spare 2m of twin flex, I effectively made it a 6m circuit.
    I also have a single strip LED light running from the same circuit. Therefore total load when my 40 litre fridge compressor is running at full speed (~4 Amps) and the LED strip is on (0.3 Amps) is 4.3A. Lets call it 4.5A for roundings sake.
    Therefore according to the equation to work out Voltage drop, 6m (conductor length) x 4.5A (load) x 0.17 (an ISO standard) = 0.459. 0.459 divided by the conductor area of 4mm2 = 0.11475. Apparently a voltage drop of anywhere from 0.1V to 0.15V is acceptable.
    Prior to shortening my cable my voltage drop would have been around 0.19V, a little too high.
    My joins are all soldered and the fridge plug is an Anderson plug. Theoretically there is probably some voltage loss in there somewhere too, but I'm not going to bother counting it as I think it would be pretty minor.
    Anyway, thought some might find this an interesting exercise for their own vehicles.
  5. The Following 2 Users Say Thank You to FNQGU For This Useful Post:
    menace 2 (28th January 2014), Woof (8th January 2014)
  6. #3124
    Geelong, VIC
    Finally got the rear door diner from DCM customs on the troll, looks fantastic and when we went to port Campbell for a day trip I had a few admiring glances
    Sent from my GT-I9305 using Tapatalk 2
  7. #3125
    Pics brother...
  8. #3126
    I was told by an auto elec that anything up to .4v is o.k. Obviously the lower the better of course. ..
  9. #3127
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Yeah, lower the better or you are effectively reducing usable capacity of your battery by whatever your voltage drop is.
  10. #3128
    Patrol God Stropp's Avatar
    38 Post(s)
    Got the turbo and inter cooler on just need to get it tuned now, it also has a very low whistle when she is on boost.
  11. The Following 3 Users Say Thank You to Stropp For This Useful Post:
    Avo (11th January 2014), Clunk (9th January 2014), Woof (11th January 2014)
  12. #3129
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Cleaned out all of the crap from two kids, two dogs and a wife after travelling from Albury to Innisfail and then on to Darwin, there was enough food hidden in places you thought you could never store stuff to have a three course meal.
    PS Chey ran sweet as for 7400 km.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  13. The Following 3 Users Say Thank You to Ian2011 For This Useful Post:
    BigRAWesty (10th January 2014), Stropp (9th January 2014), Woof (11th January 2014)
  14. #3130
    Quote Originally Posted by Ian2011 View Post
    What sorta mileage are you getting as a tourer for your rig with the Chevy??
