Results 1 to 10 of 10
Thread: gq hubs to gu
    Sep 2013
    Port Lincoln SA
    gq hubs to gu
    Hey all, just killed my hugs on my gu and dont have the money to get new ones, or even after market ones, so just wondering if i get a second hand set of gq ones will they fit and what will i need from gq to fit them
    As in locking hubs? Bolt straight up.
    Unafordable
    4 Post(s)
    They will fit and will be better than anything else on the market however that also means they're lot harder to get. You will need new set of bolts (shorter) as well as shim/spacers to get right clearance.
    Honestly if you can find genuine GQ second hand hubs which are cheaper than any aftermarket new ones than let us know where from.
    Above applies to manual hubs only, auto units are straight fit.
    Quote Originally Posted by Rumcajs View Post
    What he said mate. I would expect you to get the bolts with the hubs though and the egg ring spacer must be part of the deal.
    Yes they would be considered an upgrade. If yours are auto hubs and you can find auto hubs off a GQ then they are identical. Expect to pay $150 to $200 for GQ manual hubs
  5. #5
    Sep 2013
    Port Lincoln SA
    ok cool, so as long as i take all the bits off they will fit up going to try a few places around my area and see what i can find
    Thanks for all your help
  6. #6
    Aug 2010
    adelaide
    so what has happened to them if its the auto part that has shit itself you can remove ring and turn them into manual
    here is a link to this
    http://www.nissanpatrol.com.au/forum...Q-GU-auto-hubs
    OH LEATHER IS NICE
  7. #7
    Sep 2013
    Port Lincoln SA
    yeah i have done that to them before, now one has broken completely and the other wont stay locked in
    Are the GQ auto hubs any good as i have just found a pair that i can get, just need to know if they any good
    Sep 2013
    Port Lincoln SA
    Hey all
    GQ hubs are installed, now i got to get some mates to join this arvo and head out sand and test them out
    Thanks for you help and advice
  9. The Following 3 Users Say Thank You to dune-mad-patrol For This Useful Post:
    Family4x4 (22nd May 2014), MudRunnerTD (4th January 2014), my third 256 (4th January 2014)
  10. #9
    Beginner Fakeofergbo's Avatar
    dune mad patrol just wondering how your conversion went? i am looking at doing the same thing as i have been advised that auto hubs plus an air locker is bad news, i have sourced a set of gq manual hubs for 100 bucks. did they bolt straight in? what is this egg ring spacer and shims i am hearing about, or are those parts all included with a gq hub?
  11. #10
    They should included with the hubs when you buy them mate, make sure the seller includes everything then they are a straight bolt up. $100 is a good price.
