Page 18 of 262 FirstFirst ... 1617181920 ... LastLast
Results 171 to 180 of 2619
Thread: The Knife Thread
  1. #171
    How do you sharpen using a stone??
    I was tought figure 8's
    Push away so you don't get that burr on the cutting edge, I also use Brasso and wet and Dry then polish.
    just etched a knife after using those whet stones, you should be able to see how the softer steel is etched leaving
    the harder steel
  3. The Following User Says Thank You to threedogs For This Useful Post:
    oncedisturbed (18th December 2013)
  4. #173
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Have been reading mixed versions of sharpening, with and against grain of the blade. With bur and without bur.
    Best finish still seems to be from using a strop though. Will try and find it but 1 guy fiinishes off by using a sheet if glass
    www.swat4x4.com
  5. #174
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by oncedisturbed View Post
    Theres a knife maker in Hahndorf (Sth Aust) that finishes on glass
  6. #175
    Dad used to re finish his razor blades on the inside of a glass cup.
    Glass is flat and not many use a strop these days, except all my old teachers.
    Reckon growler may have copped a few too, sorry mate lol.
    Strop removes the burr and polishes it a little IMO
  7. #176
    Patrol God Stropp's Avatar
    38 Post(s)
    Young bloke just gave me an early Xmas present not sure of quality but it looks good.
    Bloody pic has gone upside down again?
  8. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    oncedisturbed (22nd December 2013), threedogs (22nd December 2013)
  9. #177
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    i was taught the same but i found in the end i was digging a hole in the middle of my stone. straight forward and backward motions is the trick and make sure you use both edges of the stoneif you understand my meaning
  10. #178
    Had a ringer on a bush job years ago who carried a small stone with him and every night he unfolded his buck and did two passes
    one forward and one return,all night he would do that. He is like me and try to remove the shoulders so the knife is basically a big wedge, My butcher knives are like this
    and bloody sharp as. "cause we all know accidents only happen with dull knives' Doesn't explain why I always cut my self though. lol
    Crap steel wont hold an edge and never will. I think 27 degrees is what they say, but 27 degree is found on heaps of things, Baja Claw eg
  11. #179
    Feb 2012
    30 Post(s)
    most blades are edged at roughly 23 degrees, some right down to 15 and even 10 degress but it will depend on whether it is a bevelled edge or accute edge
    Stropp, that is an awesome knife.
    I have just ordered a new sharpening kit that adjust from 10-27 degress depending on blade type with 400, 800, 1k and 1500 grit stones and a 10k wetstone as well for finishing
    www.swat4x4.com
  12. #180
    38 Post(s)
    Thx Jason, wasn't sure but it certainly looks good and has a reasonable scabbard but it doesn't feel super sharp but that may be because of my cooking knives that I keep very sharp. I should say the front of the blade is not that sharp, from where it curves that is very very sharp.
