I can give you mine, I do sometimes have different readings to what others get or max out at.
TD 4.2 Ti engine
Pyro gets up to 580 - 600 (sometimes more) degrees on a long climb on road, about 500 - 550 off road if going hard.
Oil about 55psi at 100k in 5th. 24 at idle, peaks about 85 plus when cold.
Water 70-75 deg C at 100k in 5th, goes up to 95 when on a long climb on or off road.
Still learning my parameters but so far so good. Only had the oil and water gauges for 3 months.
