i have a 2013 gu and the right hand front wheel when you try wobble it feels as though
the wheel nuts are loose has a bit of a knock noise but the nuts are tight any ideas
Ron
Ron
Look at your tie rod ends etc any steering linkages
EDit jack up and check your rears as well, better find my wheel nut thread lol
Can you wobble it from top, to bottom. If so, it may need the wheel bearing adjusted.
i haven't jacked the car up i just grabbed the top of the wheel and gave it a push pull
it also makes a knocking noise when i go over small bumps but not all the time
Reckon Mudnut is on the money, I had the same & started this thread. Worked for me.
http://www.nissanpatrol.com.au/forum...-wheel-bearing.
Macca
Wow on a 2013 model, wear already, how many Ks are on the Odometer
Oldmate,
Mine did it from new too, and it drives normally ....
I didn't believe it but a friend asked if he could check mine against his, as when he had a wheel alignment done, they picked up this top to bottom movement saying his car needed huge repairs.
Checked mine and it was the same, with an amount of movement and a clunk to go with it.
He proceeded on his trip as it was, and went from Melbourne to the Kimberley and back - so it can't be too bad.
Get Nissan to check it at the next service if you are really worried.
Mic
well at least it will be covered under warranty.
well i had Nissan do the 20,000k service the other day and they couldn't find the problem. they said it has aftermarket suspension its probably to do with it
so i took it to Arb and they said the spring is rubbing on the tapered seat and could fix it by putting 15mm spacers on. i took it to another mechanic for him to look
at it and guess what the wheel bearings are loose on both front wheels what the f#ck how did Nissan not find this problem
Ron
