Love the car and work you have done to it so far. After Xmas and rego might be time to pull mine apart and do the same thing
Parksy (16th December 2013)
Parksy what are the two uprights welded to your diff ??
Think you should get shares in Dynamatt LOL
Lol 3d! With regards to the uprights, what do you mean? Are you talking about the rear diff?
The upper arm brackets?
Yeah I thought you had a different set up??
Take it your sold on that Dyna mat, after reading your thread and Kallens looks like its a must do
Absolutely, doubled up with the foam, it has made a massive improvement in road noise.
Bought some adjustable rear upper arms off eBay. Quite impressed with how much stronger they look in comparison to the originals. At this point the patrol is 100% rebushed.
Was able to readjust the diff pinion angle, and with only a 2" lift, it still made a difference to vibration levels. Didn't even know I had a vibration issue until I fixed it.
Stropp (15th February 2014)
Good Work keep it up
Parksy (16th February 2014)
Parksy, did you end up putting dynamat/foam on the inside of the roof? I thought I saw somewhere that you were considering it.
BigRAWesty (24th February 2014)
