Page 299 of 1057 FirstFirst ... 297298299300301 ... LastLast
Results 2,981 to 2,990 of 10565
  1. #2981
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Patrol a part mate. Ring up and mention your here and they'll look after you.. Also worth getting new bolts while your at it..
    Thanks good point with the bolts
  2. #2982
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Well I got new body mounts.
    Bloody hell.. Pic is worth a 1000 words..
    I guess that's not to bad for half million k..
    So I'm am now on the home straight to on the road again..
    Did you do the rear mounts as well? Most kits don't come with the rear mounts for some reason
  3. #2983
    I actually caught up with Paul today at Patrolapart. We're going to help each other next year and in discussions now.
    They are really kicking goals down there
    Definitely mention your from here Gary, they'll look after you.
  4. The Following User Says Thank You to AB For This Useful Post:
    Winnie (10th December 2013)
  5. #2984
    Nov 2013
    Southport
    Well i'm bout to add the Daves Valve and a Turbosmart Boost control to it so there ya go...
    2008 GU6 Patrol ST 3.0 ZDDTi Manual. Radio gear Icom 706 MK2G HF/VHF/UHF, Icom Pro 400 UHF, Dominator 12000lb winch, True 100w HIDs spotties, Ironman bar light 30w, RAW Predators shocks all round, Touring rack with 2.5x2.5 annex n mossy net. Rooftop tent etc etc etc.
    If ya can't be good, be good at it.
  6. #2985
    I asked for the lwb kit and it had 10..
    But according to the receipt (and my car) the 1st and 2nd rows are the different ones.. The rear 3 rows are the same..
    Awesome stuff. Look forward to it
    Carpets in, rear and drivers seats are in.
    It's getting close.
    But dam the carpet is tight over the tunnel with double foam..
    Fiddling with the boost and needle valve
    but a post the other day had me thinking so I've turned up the chip to 8
    If there is no puff of black smoke its not quiet right
  10. #2989
    Nov 2010
    6 Post(s)
    Attachment 37841
    Just measured my mounts compressed at 35 mm what do you have now?
  11. #2990
    That's not true exactly. My car only blows a tiny bit of smoke on very rare occasions and it's making a lot more power than yours. That means that if I had the means I could be pouring more fuel into it and making more power, or I could turn boost down a bit and keep the same power I have now, but my EGTs would go up. I'd actually be keen to try turning it down to say 14 and see how much the EGTs change, but I took it to a professional for a reason, because he knows a lot more than me and he recommended to keep it at 16psi until I do more fuel upgrades.
