Well the car is back together and working.. Nearly almost 100%...
The dash cluster is doing something weird.
The Fuel gauge is sitting at 3/4 full with maybe 5 liters in the tank, and volts, oil pressure and temp are off the top.
Speedo responds to speed changes so is working in my eyes, but tachometer is slightly high, showing 1200rpm at
Idle..
It was working fine before the strip down, and no wiring was fiddled with while doing the insulation install so unsure where to start..
I have pulled the cluster out again to ensure all plugged in correctly and they are, so any suggestions as to where from here??
