Results 11 to 20 of 22
Thread: 2.8 got HOT
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    There is no bleed on the 2.8 from what I have found, the radiator cap is the highest point in the cooling system, And if there is one somewhere, I have yet to find it.....
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
  2. #12
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    these are the causes for over heating according to the manual
    Overheating Cause Analysis
    Symptom Check items
    Cooling
    system parts
    malfunction
    Poor heat transfer
    Water pump malfunction Worn or loose drive belt
    Thermostat stuck closed —
    Damaged fins
    Dust contamination or paper
    clogging
    Mechanical damage
    Clogged radiator cooling tube
    Excess foreign material (rust,
    dirt, sand, etc.)
    Reduced air flow
    Cooling fan does not operate
    Fan coupling does not operate
    High resistance to fan rotation
    Damaged fan blades
    Damaged radiator shroud — — —
    Improper coolant mixture ratio — — —
    Poor coolant quality — — —
    Insufficient coolant
    Coolant leaks
    Cooling hose
    Loose clamp
    Cracked hose
    Water pump Poor sealing
    Radiator cap
    Loose
    Poor sealing
    Radiator
    O-ring for damage, deterioration
    or improper fitting
    Cracked radiator tank
    Cracked radiator core
    Reservoir tank Cracked reservoir tank
    Overflowing reservoir tank
    Exhaust gas leaks into cooling
    system
    Cylinder head deterioration
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  3. The Following User Says Thank You to patrol2.8 For This Useful Post:
    brendi (12th December 2013)
  4. #13
    Nov 2011
    vic
    And according to the book this is how you refill it and bleed it
    —REFILLING ENGINE COOLANT—
    10. Install reservoir tank, radiator drain plug, and cylinder block
    drain plugs.
    + Apply sealant to the thread of cylinder block drain plug.
    Cylinder block drain plug:
    : 34 - 44 Nzm (3.5 - 4.5 kg-m, 25 - 33 ft-lb)
    11. Fill radiator and reservoir tank with coolant up to the MAX level
    and install radiator cap.
    For coolant mixture ratio, refer to MA-11.
    Coolant capacity (With reservoir tank): ! (Imp qt)
    RHD models
    Without rear heater 11.8 (10-3/8)
    With rear heater 12.9 (11-3/8)
    LHD models
    Without rear heater 11.6 (10-1/4)
    With rear heater 12.7 (11-1/8)
    Reservoir tank capacity (for MAX level):
    1.2 ! (1-1/8 Imp qt)
    Pour coolant through coolant filler neck slowly to allow air in
    system to escape.
    12. Warm up engine to normal operating temperature.
    13. Run engine at 2,000 rpm for 10 seconds and return to idle
    speed.
    + Repeat 2 or 3 times.
    Watch coolant temperature gauge so as not to overheat the
    engine.
    14. Stop engine and cool it down.
    + Cool down using a fan to reduce the time.
    15. Remove the radiator filler cap and check coolant level.
    + If necessary, refill radiator up to filler neck with coolant.
    16. Refill reservoir tank to Max line with coolant.
    17. Repeat step 12 through step 16 two or more times.
    18. Warm up engine, and check for sound of coolant flow while
    running engine from idle up to 2,000 rpm with heater temperature
    control set at several positions between COOL and HOT.
    + Sound may be noticeable at heater water cock.
    19. If sound is heard, bleed air from cooling system by repeating
    steps 12 through 16 until coolant level no longer drops.
    + Clean excess coolant from engine.
    SMA003D
    SMA182B
    SMA412B
    SMA004D
    ENGINE MAINTENANCE
    Changing Engine Coolant (Cont’d)
    MA-
  5. The Following User Says Thank You to patrol2.8 For This Useful Post:
  6. #14
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    Quote Originally Posted by trekster View Post
    I think there is on under the inter cooler at the back along the fire wall where the heater hoses are, unless mine is an add on.
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  7. #15
    Nov 2012
    Coffs Harbour, NSW
    Quote Originally Posted by krbrooking View Post
    Maybe so, I'm used to the bleed generally being at the highest point of the system to get the air out, I'll have to have a look at mine as it would be interesting to know, mine definitely has none on the thermostat housing as that is 1/3 of the way down the motor.
    Cheers,
    Eric.
    1998 GU RD28T: RIP
  8. #16
    Nov 2011
    vic
    2.8s going by the book can only be bled with the radiator cap off re above post tells how its done its an easy job to do
  9. #17
    Mine must be an add on then as it's the highest point pretty much in line with the rocker cover.
  10. #18
    Dec 2013
    on this theme of over heating is the a way to tell how accurate my heat gauge is working?
  11. #19
    Patrol Guru
    NT
    Mine has it too.
    As for accuracy, it's extremely accurate if you use it as a cold/normal/too hot indication.
    Ecu talk.
  12. #20
    Dec 2013
    carrum downs
    thanks for your help guys re bled the cooling system and now all is good atm
  13. The Following User Says Thank You to brendi For This Useful Post:
    macca (12th December 2013)
