Results 1 to 10 of 19
Thread: Harris Hard Case problem
    Expert LachDiggityDog's Avatar
    Jul 2013
    Brisbane, QLD
    Hi all
    Well it's official my Hard Case will not fit due to my caster correction plates, the top bolt is fowling it from going all the way back.
    Has anyone else had this issue?
    Cheers Lachy
    06 TD 4.2 coil cab, 3 inch lift, front ARB air locker.
    Aug 2010
    adelaide
    get the grinder out
    OH LEATHER IS NICE
    Western suburbs of Melbourne
    12 Post(s)
    Start problem solving and get the thing on already.
    brisbane
    The front of Mine hits the panhard rod but that from my radius arm spacers bringing the diff forwards. I just modified the guard with a hammer and a big one at that .
  5. The Following User Says Thank You to megatexture For This Useful Post:
    LachDiggityDog (13th December 2013)
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by lachdiggitydog View Post
    hi all
    well it's official my hard case will not fit due to my caster correction plates, the top bolt is fowling it from going all the way back.
    Cheers lachy
    so many mods that are all important and you cant fit
    the diff protector on takes less than 5minutes normly
    grinder and hammer if you will
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by LachDiggityDog View Post
    Hi all
    Cheers Lachy
    Lachy is it possible to remove the offending bolt, fit the hardcase and replace the bolt which should now be in front of and clear of the hardcase?
    Or is the bolt that close to the diff?
    I am a little confused why you can not get it to fit. Which bolt is it the top or bottom?
    http://www.nissanpatrol.com.au/forum...5&d=1385549801
    Macca
    Jul 2013
    Brisbane, QLD
    Hi Macca it's the top bolt that is fowling I haven't tried to take the bolt out yet as you need to take all the weight off it to do so even then I think it is still going to hit. Ill post some photos when I finish work. I have already cut the thread flush to the bolt as you will see in the photos I will put up.
    Did you have a similar issue?
    Oct 2010
    Old Bar, NSW
    I don't have the plate like you. It basically pushed / wriggled past the bolt and was a neat fit that slid home around the diff really easily.
    Your plates are mounted in another hole by the look of it, did you put them on? and drill another hole in the bracket on the diff
    Macca
  10. The Following User Says Thank You to macca For This Useful Post:
    LachDiggityDog (6th December 2013)
  11. #9
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    thankyou macca your help, or trying to help is a bit more usefull than just get it on already and get the grinder out!
    GQ Snorkle Lockers front n rear
  12. The Following 2 Users Say Thank You to 89gqpatrol4x4 For This Useful Post:
    LachDiggityDog (6th December 2013), macca (5th December 2013)
  13. #10
    Finally did the trip to the po box. Looks good Mal, thanks!
    Ill fit up this weekend.
