Results 1 to 9 of 9
Thread: Anyone help me with an injector on a tractor?
    Patrol Guru SonOf's Avatar
    Dover, Tasmania
    Hi guys,
    I have a farmliner 445 tractor that I just fitted a new injector pump to. It is gear driven and I was careful to make sure eveything went back same as it came out so I didn't stuff up the timing. Have mannually bled the system and got the air out but when I crank it over I am not getting any fuel coming out the injector lines?.
    The pic is of the old injector but you get the idea.
    Know I am asking bit but before I call the diesel guy here and sell my next born and their first born to pay for it, anyone have any idea I might try?
    cheers
    Seemed like a good idea at the time
    sound like there could be a wire off,had this prob not long ago on a JD,where the fuel pick up is on top of the tank you should find wires for the fuel pump,maybe this wire has come off or broken,,we took the plate of the floor and managed to get to it soldered it back up and away we went,if that doesn't help or wrong let me know and i'll ask me boss tomorrow.or tonight if I see him..
    Cheers mate
  3. The Following User Says Thank You to Avo For This Useful Post:
    SonOf (4th December 2013)
    Does it have a fuel shut off solenoid? Going by the pick it may have. That rod running up the side of the pump maybe it???
    If it is, see when you crank it over whether its moving or not. If its shut off it wont let the fuel through. Also you need to know if the solenoid is energized to run or energized to shut down.
    If that lever it what I think it is and it doesn't move, get someone to move in the opposite direction whilst you crank it.
    Thats all I got from my old Perkins days.
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    That injector pump has no cut off solenoid, it's a "pull stop" Bleed the be jesus at the pump, loosen number 1 injector, whiz the crap out of it , when it starts, tighten the injector, the cut off lever needs to be forward. aerostart is your friend here!!
    Cheers, the ferret.
  7. The Following 4 Users Say Thank You to the ferret For This Useful Post:
    Avo (2nd December 2013), dirtygu (2nd December 2013), mudski (2nd December 2013), SonOf (4th December 2013)
  8. #5
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    x2^^ make sure you have bled the pump completely, there will be 1 maybe 2 bleed screws on the pump. I can see on the side of the pump at the end towards the fuel lines and there might also be 1 at the other end near the mounting flange.
  9. The Following User Says Thank You to firm351 For This Useful Post:
  10. #6
    Dover, Tasmania
    Appreciate the feed back gents. Fuel is gravity fed to the fuel transfer pump (seen under the injector pump) the primer lever is located at its base.
    2 bleed screws on the injector pump, one you can see right near the injectormline outlets and the other is on the other side at the top, pr!ck to get to but have bled them till now just diesel flows, no bubbles of air at all. Uses a thermostart plug instead of glow plugs. Twin filters which have both been bled, no air left.
    Correct in that this is a lever shut off for the fuel and I have double checked the correct direction. Will muck with it again this afternoon when I get back from work.
    when I pump,the primer I can hear the diesel flow back to the tank through the return line so know it is getting through. The attached pick is better detail of fuel system setup.
    Thank you again gents, greatly appreciate the help.
  11. #7
    Advanced senility Brisat's Avatar
    Dec 2012
    Dakabin QLD
    Had this problem with a David Brown, when they did the pump they put the stop control on back to front, Pull out to run, push in to stop
    That will most probably be the trouble
    The mind is still making contracts that the wallet can't afford
    1993 Maverick TD 42 mit einem Turbolader, triple battery setup with 2 twin battery units & solar panel, 21/2 & 3 in exhaust, 5 dash mounted gauges, 55 ltr beier frig/freezer, broken winch, UHF & HF radios hf auto antenna, rooftop tent, portable satellite tv system and the ship hanging on the back [4.2 m runabout with 50 johnson] happy hour
    Dakabin 4503 QLD
    WARNING: Towballs used for recoveries,can and do kill people and damage property and also scare the shit out of people standing next to the car
  12. The Following 2 Users Say Thank You to Brisat For This Useful Post:
    SonOf (4th December 2013), Stropp (6th December 2013)
  13. #8
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Got to love the internet and knowledge sharing...
    1999 GU 4500 dual fuel
    Il dado è tratto
  14. The Following User Says Thank You to NP99 For This Useful Post:
    SonOf (6th December 2013)
  15. #9
    Dover, Tasmania
    Finally got it going. Re-bled the whole system and checked the stopmlever etc. Found it was the throttle lever on the pump. Was not opening to let fuel flow. Took the leber off and manually worked it open with set of pliers and this seemed to work. Old girl now fires up and runs like a dream. Thank you all for the assistance.
