Page 22 of 36 FirstFirst ... 2021222324 ... LastLast
Results 211 to 220 of 356
Thread: Deaths from towballs
  1. #211
    Yea most use a tongue which replaces the ball hitch and has a hole in the end for a 16mm bow shackle.
    But as MR said you can always just insert the strap into the receiver and pin it.
    Advanced fxst78's Avatar
    Dec 2013
    South Canberra
    Pin in the receiver is the simplest safe way IMO, the recovery hitches are good if you recover a lot. For me, I try to not need recovery so am happy to use the pin on the odd occasion it's needed.
  3. #213
    Advanced Dazzalco's Avatar
    Oct 2013
    Perth
    Talking about that I was down at Preston beach on Sunday and saw a landrover bogged to the axles and his mate was getting ready to snatch him out using the tow balls on both cars. I went over to them and informed them that using towballs is not safe and showed them how to safely snatch a car out using the tow hitch pin. They were new to 4wding and did not know hopefully they won't make the same mistake again
  4. The Following User Says Thank You to Dazzalco For This Useful Post:
    threedogs (3rd December 2013)
  5. #214
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by Dazzalco View Post
    Good job mate:-)
    Hello from Under Down Under!
  6. #215
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    That's it mate education! You can stand back a say what a bunch of w#$kers, but if they don't know they need to be told, well done.
    GQ Snorkle Lockers front n rear
  7. #216
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    good stuff im still finding people out there are unbelievable I once helped a couple of guys out who were about to do a snatch off the towball stoped and gave em a hand while explaining the dos and don'ts about recovery anyway ran into them again later in the day and guess what snatch straight over the towball
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  8. The Following User Says Thank You to patrol2.8 For This Useful Post:
    threedogs (5th December 2013)
  9. #217
    Thomastown, Melbourne
    6 Post(s)
    Quote Originally Posted by patrol2.8 View Post
    Well its simple then... darwinism should come into play soon and you dont want to be near them.. Explain it once and how you are not telling just to make yourself look the know it all but for there own safety, if they take heed then good on them and well done but if they dont then...GET STUFFED!!!!!!!
  10. #218
    Expert kind's Avatar
    Nov 2013
    brisbane
    Would it be ok to just put a D - shackle and snatch off it?
    1996 GQ 2.8TD 3" straight though, draws and oh so much more
  11. #219
    Quote Originally Posted by kind View Post
    No mate not at all. That is a factory tie down point only and is designed to be used during shipping from Japan and if your car ever needs to go on a flat bead (touch wood)
    Under No Circumstances should you every use it in any form of recovery.
    Stay safe and thanks for asking.
  12. #220
    Nah mate, that's just a tie down point used during shipping I believe.
