Results 1 to 10 of 12
Thread: Egr block time
    Oct 2013
    Egr block time
    Hi. I'm going to block the egr and remove the butterfly at the inter cooler. Can someone show me the place to block please? Thanks in advance.
    Sep 2013
    what is the purpose of doing this ?
    Most block at the top of the EGR pipe just under the engine cover on LHS
    looking over bullbar, you only need to remove bolts and slip blocking plate in position.
    What motor is this happening to
    Oct 2013
    looking over bulbar, you only need to remove bolts and slip blocking plate in position.
    Sorry. Forget that bit. TD42TI.
  5. #5
    Quote Originally Posted by GU_Mick View Post
    Here ya bud.
    GU_Mick (10th November 2013)
    Oct 2013
    Here ya bud.
    Thanks mate
    Nov 2013
    SE QLD
    I have a TD42Ti as well and have been told that you should block the EGR off. What is the advantage in this and are there any trade offs or disadvantages? its for pollution control, right?
    Quote Originally Posted by viking View Post
    What the EGR does is allow some spent exhaust gas back into the intake manifold and then into the engine. You ever seen the inside of your exhaust pipe? Kind of black, slightly oily and sooted up. Well this is what happens to you intake manifold and over time it clogs up your intake manifold. Think of it like, cholesterol. The inside size of the the air intake gradually gets smaller. Not only this but your engine is not sucking in clean air. So your engine won't go as good as it should. Not too mention the detrimental affect this has on the life of your engine.
    This mod is illegal though. The reasoning for the EGR is just for environmental purposes. No advantage at all for your engine.
    Here is two pictures of what happens to your intake when you DONT block the EGR.
    If you do it I would advise on remove the entire intake manifold and giving it a good clean out.
    viking (18th November 2013)
  11. #9
    Nov 2013
    SE QLD
    Thanks for that, I am hearing you. I will attend to that straight away. Of course I would never do anything illegal or bad for the environment 'wink'
  12. #10
    Patrol Guru TimE's Avatar
    Canberra
    Check this post go to post 169 for a photographic step by step for the 4.2, I used a blanking plate from the Ferret.
