Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: Dual 12v compressor and air tank upgrade
  1. #41
    brisbane
    Mate depending on how much the compeessor runs througout the day your gonna need plenty of amp hr unless you run the car, compressors can suck alot of amps how long do you run it for ?
  2. The Following User Says Thank You to megatexture For This Useful Post:
    threedogs (16th November 2013)
  3. #42
    @ SD don't know your driving style but you think tank is OK for ramp over angle.
    Love the led lighting, take it they are only led strip lights?
    Awesome times to inflate but no time for mandatory beer during air up, lol
    Edit @ mega anything up to 65 amp maybe more ,
  4. #43
    brisbane
    Sca don't say what amps/ @ psi. Draw the compressor is so you may need to test it if you want a fair idea of what your going to use.
  5. #44
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    I would have put pics up sooner but i had a little accident on push bike, rather nasty one.
  6. #45
    Mar 2013
    I'm always keeping an eye on my battery's. The compressors I am running are big and these two together are as good as my belt driven one in my workshop.
  7. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    Stropp (22nd November 2013)
  8. #46
    Mar 2013
    Quote Originally Posted by megatexture View Post
    Its hard to when i was using the compressors for my nail guns it was for 2 long days.
  9. #47
    Mar 2013
    Re-wire begins,
    I solider heat shrink everything,
  10. #48
    Mar 2013
    I should have seen this, I cant do it this way because it physically will join the wiring for both batteries . I would love some input here, the only way I can see out of this is if I go ahead and add the third battery now.
  11. #49
    Mar 2013
    Not sure who is following but after some thought I pulled the Dual battery switch/isolator apart and worked out the contact points and filed down the part where the switch makes contact joining the batterys.
    So from the Common it only able to select ether source 1 or 2 no 1+2.
  12. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
  13. #50
    brisbane
    You do know you can buy them like that? Mines 1 , 2, 1+2 and off and was under 30$ rated 150 amp
