15th November 2013, 05:14 PM
Liquid-moly engine oil resealer
G'day legends,
If anyone has any experience with using engine oil gasket resealer and can release some wisdom in regards to:
Pros,
Cons,
And in particular the liquid-moly engine oil resealer, it would be kindly appreciated.
I have the rd28eti in a 98gu, about 280k on odo.
Even though you wouldn't know it by checking the dip stik she leaves the occasional spot on the driveway. And it's a little messy on the underside (I know I make a little mess when I change the filter). Oil and filter get changed every 5k +-.
I have found that a new sump gasket is about $100 and rocker cover gasket $75!!!! And a tin of resealer is about $16-20.
Will the resealer work if the leak is only slight?
I apologise in advance if this subject has been done to death already. Please, no liquid-Molly reps.
Cheers.
15th November 2013 05:14 PM
15th November 2013, 07:45 PM
I have no experience with any re-sealer mate. But in my opinion if it clogs up your gaskets what else is it clogging up???
15th November 2013, 07:50 PM
Doesn't work by clogging gaskets, it works by causing them to expand.
The Following 2 Users Say Thank You to Parksy For This Useful Post:
oilburner98 (16th November 2013), threedogs (16th November 2013)
15th November 2013, 11:23 PM
Patrol Guru
I have used many liqui-moly products, and would highly recommend them.
I'm guessing you are referring to his one?
http://www.liqui-moly.de/liquimoly/p...oiladb=web.nsf
I also would suggest rislone products as I had used them in my old range rover (when I couldn't get liqui-moly).
There's a couple of different ones.
http://rislone.com.au/catalog/view/1...e-repair-44110
http://rislone.com.au/catalog/view/1...l-repair-44240
Have used the first one in my 4.5 GU with no issues.
Evo
Cheers,
Evo
The Following User Says Thank You to Evo For This Useful Post:
