Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 113
Thread: Car Fridges , help with some stupid questions please
  1. #61
    Expert Shaun 4x4's Avatar
    Secrets
    Didn't sound like it come to think of it.
    But was really listening as was in a rush to load it up and head down the beach
  2. #62
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    Quote Originally Posted by Shaun 4x4 View Post
    Well that was the plan.
    Out for about 4-5 hours today and the fridge wasnt getting any cooler.
    Been reading they need to be on a few day the first time round to get working properly.
    I hope this is the case other wise it will be going back quick smart.
    definately does not sound right......
    dont want to state the obvious but is the power setting set correctly...
    first thing i would do is run it on 240 volts first , empty it should be at temp in 10 minutes.. when that works set the battery limits(i have mune on low as i run agm deep cycles so happy to go low on them) and get that going..
    hope things work for you
    Scotty
  3. #63
    Secrets
    Thanks Scotty.
    Mine was set on medium.
    Will change it to low as I'm running it of my aux yellow top.
    Yer it is filled to the brim with bottle ATM. Lol
  4. #64
    Patrol God Stropp's Avatar
    37 Post(s)
    I have the companion mammoth 47 ltr with metal body and it's great, works well and priced very well too, haven't had any dramas yet although I will be looking for a bigger one for the Simpson trip to hold food. I do have an 80 ltr trailblazer which is the best fridge in my opinion the downside is it won't fit in the patrol with the drawers due to the 3" insulation around it so I will need to sell it and buy a smaller dimension fridge.
  5. #65
    brisbane
    God dam it.
    It must be my the 12v supply.
    Got it plugged in at home now for the last hour and it's already down to 6C.
    Will have to suss that out next weekend now.
    Not using he factory plug are you as when the cars off so is the plug..
  6. #66
    Secrets
    Quote Originally Posted by megatexture View Post
    Nar not that silly. Lol
    It's one someone has put in the back before I owned it.
    Pulled it out and looks to only be 2.5mm cable.
    So I guess with the volt drop from that and the power setting being on medium it was under the level to run the compressor.
    But the screen was still lit up.
  7. #67
    brisbane
    Yea I run some thick stuff for my fridges and swap the cig for a merit plug while your at it much stronger connection
  8. #68
    brisbane
    You never know sometimes lol
  9. #69
    Secrets
    This is true.
    Gonna get some 6mm from work tomorrow.
    Should do the job.
  10. #70
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    This is true.
    Should do the job.
    Do you know any good sparkys mate lol
