Results 1 to 10 of 13
Thread: Does blow by really need to be returned to the engine?
    Sep 2013
    Gippsland
    Doing an airbox upgrade and havent really got anywhere to return the blow by back into the pre turbo piping on a TD42t. Does it really need to get put back into the combustion process or is it just for emissions control?
    GU with a few bits and pieces.....
    Legally... yes. Like you said it's just emissions control. Mine is vented to atmosphere through a catch can.
  3. The Following User Says Thank You to Winnie For This Useful Post:
    patrolla (11th November 2013)
    Yeah go the catch can mate. Motorcyclists will thank you
  5. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Bloodyaussie (11th November 2013), threedogs (11th November 2013)
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    This is why I ride in the tyre tracks and not centre lane on road on my drz400 riding on knobbies is hard enough let alone in the wet with oil spray
    Such is the rule of honour.
  7. The Following 2 Users Say Thank You to macca86 For This Useful Post:
  8. #5
    Nov 2013
    SE QLD
    blow by is just EGR right? I don't like the idea of it either but can you get a catch can that looks professional and like a factory fit so as to pass a quick roadside inspection and not get pinged?
  9. #6
    Quote Originally Posted by viking View Post
    Search eBay for a Provent 200
  10. #7
    Nov 2013
    SE QLD
    thanks mate..
    '04 GU TD42Ti ST, standard but with helpful advice here, will mod for off road touring.
  11. #8
    Blow by is crank case pressures being vented from small leaks in the engine internals..
    But yes check out the provent.
    I really need to get onto this myself.
    Anyone in particular Dazz on this link below...
    http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40
  13. #10
    Does anyone drain straight back to sump?? Or collect and dispose of??
