Results 1 to 10 of 12
Thread: Replacement Belts for 2000 GU TD42 Turbo
Threaded View
  1. #5
    I don’t trust the catalogues. The ones listed in the Bosch catalogue didn’t fit. Bosch replaced them for me with the sizes I requested & the replacements fitted ok.
    These are what I now have on my ’06 4.2 TDi
    Air Con -13A0965
    Alternator 13A1145 *note 1150 or 1155 would be easier to get onto pulleys
    Power Steering 13A1230 * note 1245 would also fit.
    Cuppa
    The catalogues only go by OEM fitment. If the alternator, power steering or the A/c pump has been changed in its life theres a high chance the pulley sizes are not the same.
    you can just remove the belt and measure it. Just mark a line on the outside of the belt and run a tape around it to give you the length and then measure the top width of the belt. Easy peasy.
    Avo (6th April 2014)
