Results 1 to 10 of 11
Thread: Oil Leak from drivers side Engine - HELP
    Advanced jackwalks's Avatar
    Warner, Brisbane
    G'day all,
    Over the last several weeks I have noticed what I think is a small continuous oil leak from the right side of the engine. Look down at the engine, it appears dry and normal, but when I slide under the car you can see quite a large wet/ moist area.
    The leak is not enough to leave a puddle on the drive way. Now been a beginner in the mechanical area. I am hoping someone may have an idea on what the culprit is.
    I will eventually have my mechanic look, but I would like to go their with some background info, and not be told that it the flux capacitator again.
    Adam
    2001 GU II - 3.0TD Auto. ARB Bullbar - Runva 11XP Winch - NADed with Boost & EGT gauges - OME 2in Lift - Manta 3in - Dual Battery - Spotties & LED Lightbar - Uniden 80ch UHF - Rear Drawers & Engel Fridge - 3/4 Steel cage Car goes vroom
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    It could be the hose with the genuine hoseclip leaking, see of it's loose.
    Cheers, the ferret.
  3. The Following User Says Thank You to the ferret For This Useful Post:
    jackwalks (7th November 2013)
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    G'day Adam,
    is it sump oil (looks too clean) or can you tell by feel/smell whether it's coolant or say clutch fluid?
    Are all your fluid levels stable? Any idea what the tube/line is. I've been too lazy to get under mine, sorry.
    Col
  5. The Following User Says Thank You to Col.T For This Useful Post:
    Aug 2010
    adelaide
    give it a good degrease and start again looking for the first signs of leak
    yeh the mechanic will say you need a new engine
    OH LEATHER IS NICE
  7. The Following User Says Thank You to my third 256 For This Useful Post:
  8. #5
    Thomastown, Melbourne
    6 Post(s)
    You need to clean it all and then work out where its coming from mate....... no good trying to guess where when its like that!!
  9. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  10. #6
    Nov 2013
    Like Col.T said it looks to clean to engine oil, might be power steering fluid. Better pics from top near the source of the leak would help.
  11. The Following User Says Thank You to bamr33 For This Useful Post:
  12. #7
    Warner, Brisbane
    Quote Originally Posted by Col.T View Post
    G'day Adam,
    Col
    Quote Originally Posted by my third 256 View Post
    Quote Originally Posted by bamr33 View Post
    Gday all,
    Thanks for the ideas above. I have put some of the liquid on my fingers, and can not smell anything, when I first noticed the leak, it was very clear (just after I did my oil change), and a couple of days ago I have noted it is a little darker. I will definitely give the engine a good degrease and wash when I do my next service and take photos after to compare.
    I have checked all my fluid levels and all seem to be good, no noticeable drop in anything. When I drive I have no lights and engine seems to run fine with no loss of power. I am a bit stumped.
    I will keep you posted when I do my next service and hopefully may be able to solve this small issue.
    Once again, thanks to everyone for their input and advise, I have taken it all on board.
    Adam
  13. #8
    Nov 2010
    Seaview Dwns.S.A.
    G'day again Jacko,
    Reckon that's the way to go.
    Major leaks generally show up as a problem with clutch/brake/coolant/you name it but until it becomes clear what level is going down or what is misbehaving, it's all a bit vague.
    Clear after a service but now darkening up would certainly indicate engine oil but where it's from is the question.
    They say patience is a virtue but, son of a b**ch, I never got any.
    Hang in there and keep watch,
    regards,
    Col
  14. #9
    Expert Benno7's Avatar
    Nov 2010
    Did you spill any oil while doing the service? did you notice the oil leak before you changed the oil?
    Clean it off and keep an eye on it.
    a small amount of oil spilt will make a big mess on an engine.
  15. #10
    178 Post(s)
    A small amount of oil spreads a long way. After you have degreased the motor & it’s dry you could try puffing talcum powder all over the affected area & then run the motor. This will give a much clearer indication of where any leak is coming from, if indeed you do have a leak.
    Cuppa
