Results 1 to 10 of 14
Thread: Battery Earth
    Mar 2013
    Battery Earth
    I was wondering if what i had circled in the picture had any real purpose and if i would be okay not using it anymore.
    Also my battery isn't held down by anything, is there an easy way to tie it down. I got a battery tie down kit from supercheap but the rods are too long on one side and too short on the other.
    Thanks guys.
    If its an earth yes clean it up and re fix it, you'll find heaps of earth straps at different places,
    like grill, engine bay dash, front cabin , rear cabin. each section has it own earth, even left / right
    Even if you join some big long cable ties secure your battery some how, its 30kg bumping around
    could cost plenty down the track
    Is this a GQ ???
  3. The Following User Says Thank You to threedogs For This Useful Post:
    phelonius (2nd November 2013)
    Mar 2013
    Is this a GQ ???
    Yeah it's a gq.
    Do you think an occy strap work?
    Thomastown, Melbourne
    6 Post(s)
    No do not use an ocky strap..... fix it properly as you can have a fire under your bonnet from a battery jumping from its spot and coming in contact with metal ie the bonnet its self.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yes you need it, that is the main earth for the body. It doesn't need to be battery cable now you could replace it with 5mm2 wire if you like.
    Where does the red battery cable go to? a winch?. I would wrap some conduit around it.
    Mar 2013
    Red cable goes to the winch.
    What does the original tie down system look like for the tb42?
    Never ever use OCKY straps Accident waiting to happen should be banned, and don't let Kids play with them either
    If your stuck until after the week end a rachet strap will hold your battery down but call on a few mates and get some brackets made.
    SCA may have a truck size battery holder for little outlay,, but again never use OCKY strap, they will rip an eye out, hate them with a passion
    OE battery hold down may just be 2 threaded rods that will hook into each side of the tray with a cross plate to hold it firm, Don't use wing nuts use nylocs if possible
    Where you located
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    x2 with that. Seen it happen first hand to a old hilux. The battery was held in with cable ties and it fell out. very nearly caused a fire, burnt fuel line and smoke was pissing out from under the bonnet, but no actual flames, very lucky.
    GQ Snorkle Lockers front n rear
  10. #9
    Mar 2013
    Where you located
    Sydney.
    http://www.supercheapauto.com.au/onl...om=40605#Cross
    I got one of those but on one side the rod is too long. on the other it's too short.
    If i use it with something like this
    http://www.supercheapauto.com.au/onl...d=214451#Cross
    and get shorter rods would it be alright?
  11. #10
    Aug 2010
    adelaide
    go to bunnings get some endless rod and 2 washers and 2 wing nute in the fastener isle
    bend a hook on the end . measure for length and cut a little longer
    do the same for the other side
    use bracket from the kit you have
    install and all is good for a few dollare
    OH LEATHER IS NICE
