Results 1 to 10 of 10
Thread: Does that look like an EGR blanking plate?
    Aug 2013
    My08 Gu CRD
    Bought second hand a few months back. Was having a squizz under the hood and noticed some shiny rough cut stainless on the drivers side EGR pipe flange: ImageUploadedByMotorculture1382836958.078786.jpg
    Thoughts?
    I have fitted boost and EGT gauges as well as a 3" exhaust before i saw this. If this is indeed a blanking plate, should I be watching things a bit more carefully?
    You should be fine, they say all vehicles should have EGR plates fitted
    Aug 2013
    So it does look like one to you three dogs?
    I would think its behind the electrical tube under the IC like my Di.
    Got some plates here I'll measure hole centres, they are about 65mm cntrs
  5. #5
    177 Post(s)
    Hey money. I'd say it is a blanking plate, as it's got some portions of it sticking out. I don't think original gaskets stick out. I'm not near my car to check though.
  6. The Following User Says Thank You to Hodge For This Useful Post:
    Money-fishing (27th October 2013)
    Aug 2013
    Is it normal to blank the EGR before the intercooler? Did a bit of re-search, but couldn't turn up a definitive response.
    Yeah most block at the top end its a big no no pollution wise
    but is very hard to pick if blocked, act dumb if the boys in blue ask
  10. #8
    Aug 2013
    Thanks everyone for your replies. Appreciated!
    Its good to know someone has put a little bit of time and effort in to the longevity of this engine before I bought her. Now to fix the squeaky serpentine belt... It's driving me crazy :s
  11. #9
    177 Post(s)
    Quote Originally Posted by Money-fishing View Post
    I'm pretty sure I've read a few times around here mate, to only use genuine belt.
  12. The Following User Says Thank You to Hodge For This Useful Post:
  13. #10
    Aug 2013
    Yeah mate, I'm just reading up on the same now. Thanks fit the heads up.
