Page 30 of 52 FirstFirst ... 2829303132 ... LastLast
Results 291 to 300 of 517
Thread: Blocking the EGR Valve
  1. #291
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Great thread, and template. Thanks
    A&J
  2. #292
    Expert Cbates's Avatar
    Lilydale
    Might sound stupid and hello again guys! Just wondering if it's fine to do this with the tb45e on gas?
    Probably no need as patrols don't emit soot like diesels do.
    But again it probably won't hurt to suck 100% clean air..
    Quote Originally Posted by Cbates View Post
    You may want to have a read of this before making that decision http://www.swri.org/3pubs/ttoday/Sum...n-and-Cool.pdf
    From what I can understand, you wouldn't really benefit in blocking the EGR (if there is one on the TB range of engines)
  5. The Following User Says Thank You to Clunk For This Useful Post:
    Cbates (22nd October 2013)
  6. #295
    Lilydale
    Thanks mate! That's what I was looking for!
  7. #296
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    This has been a seriously good read, all 29 pages.
    I now know roughly what I need to do to my CRD.
    Got to start assembling the parts.
    cheers
    Ralph
  8. #297
    Only takes around three or four stubbies Ralph to complete the job.
  9. #298
    Advanced Jamiepatrol's Avatar
    Currently Reservoir
    Hey folks .Just got my gauges fitted and will attack the egr blank soon. I haven't pushed the car since gauges were fitted, but so far my temps are 200 on idle to about 400 round town when I gun it a little bit.
    Are these roughly the average temperstures??? I have a 2 & 3/4 beautydesert system in the car so far. I understand my EGT's will rise if I blank the EGR? Correct?
    Also with the dawes i'll be able to control the boost max and spool up rate ( needle valve). Could someone in a nutshell help me understand how more boost lowers the EGT's??
    Jamie.
  10. #299
    Check out Chaz Yellowfoot Threads on Dawes installation, it will answer all you questions and more.
    Even google it, it covers all about the imfamous ZD30 engine
    @ James is your gauge in Celcius?
    I get 450 degrees towing sitting on 110kph
  11. #300
    Currently Reservoir
    thanks threedogs. i have the autron gauge and i'm pretty sure it is celsius. i have the common rail engine. and as i said i am yet to put it under load. i will never tow so, ill have to take it up a hill somewhere and test it out. what sort of PSI boost does your sit while its towing at 110km/h ???
    thanks.
    jamie.
