Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Suspension spring rates etc
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Hi everyone,
    I was just talking to a bloke in a shop and he has said do not do the suspension if you are allowing for a winch if if I haven't got it yet? He said do it all at the same time or the springs they would use would push the top of the shock. Sounds right in theory but is that actually right? I wanted to do the suspension now then replace the bar that is on it as it is starting to rust out and add the winch. Is it better to buy what I want and install when I have it all? Cheers
    Patrol Guru paulyg's Avatar
    Ballarat
    What does he mean "push the top of the shock"? I have never heard of that, I would have thought it just sit a bit high at the front.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
    Most would fit all accessories like the heavier ones , dual battery, winch and bullbar, then fit the suspension to suit.
    Dec 2012
    Coffs Harbour
    Hi paulyg, he said with not enough load on it and especially hitting the bush would be pushing it up to hi. Don't know enough about it.
    Dec 2012
    Coffs Harbour
    Hi Threedogs, suspension is shot. Needs replacing before anything else. Limited funds so on a needs basis.
  6. #6
    Ballarat
    I see what he means but that would probably only happen when the front suspension is completely un loaded like cresting a sand dune at speed or bouncing over something.
    could you get the suspension that you want and some second hand front springs to use for now?
  7. #7
    Legendary happygu's Avatar
    Change out the suspension for the new stuff you are after, but go to someone who knows what they are doing.
    He is sort of right, but under extreme articulation most shocks will top out anyway - and they do it all the time ..... what he is talking about is that the wrong length shocks for the springs, as with too short a shock every time someone you go over a speedhump in the road, the springs will unload the weight and take the shocks to their limit.
    With matched suspension and shocks, the shocks are in the middle of their extension stroke, and it wont be too much of an issue.
    With an added winch and dual batteries, etc, it is only going to drop 10mm max. - it ain't going to be hitting the floor.
    Mic
  8. The Following User Says Thank You to happygu For This Useful Post:
    MudRunnerTD (18th October 2013)
    hes right in theory, but the chances are very unlikely.. you need to be launching the thing quite a bit to stuff em..
    what you will get is a stiffer ride until such time as the other stuff goes on..
    Quote Originally Posted by happygtu View Post
    Mic
    What he said ^^^
    Your mechanic is an idiot. The springs and shocks should be matched for length. The shocks will not "top out"!!! When you put your car on a 2 post hoist and it is lifted off the ground by the sills all 4 shocks "top out" as the car suspension droops.
    The only issue you will have is that you might buy a heavier spring in advance of the extra weight of the accessories. A firmer ride should be expected until the parts are fitted but Zero detrimental effect to the suspension components.
    Mic is correct, find a new mechanic.
  11. #10
    Dec 2012
    Coffs Harbour
    Hi Mudrunner, Not the normal blokes I talk to. I was just asking him questions because I would rather have a go and do it myself. Pretty basic just a standard 2" lift. This bloke was in a TJM shop I haven't been to before so you if you don't know you can't tell if they are telling you crap. Thanks to everyone for the info, he will obviously not be getting any of my dollars. Cheers
  12. The Following User Says Thank You to Covo71 For This Useful Post:
    taslucas (18th October 2013)
