Results 1 to 10 of 12
Thread: Where to crimp in Melbourne
    Expert Flo-w's Avatar
    I'll need a few cables crimped for a dual battery setup. I'm wondering where I could do that in Melbourne. To my surprise Jaycar doesn't offer that service (I would have payed for it). I just don't want to buy a big crimping tool for just a few connections. I'm talking 4GA so a small hand crimper won't do and I've heard bad things about the pliers & hammer method...
    Any ideas?
    '93 GQ 4.2l diesel: 3" Koni/King lift, 33" Mickey Thompson ATZ P3, 165l tanks, snorkel, roof rack, rooftop tent, CB radio, DIY storage, dual battery setup, & 50l Waeco fridge.
    RIP '95 GQ 4.2l petrol/lpg, RIP '89 Pajero
    Any good 4x4 shop should be able to crimp your cables for a modest fee,
    Can't centre pop and solder?? What side of Melb??
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    What about a local auto sparkie?
    1999 GU 4500 dual fuel
    Il dado è tratto
    Oct 2010
    Old Bar, NSW
    Your local electrician may have the crimper you want. I've go 8 from 0.5mm to 120mm but those are cross sectional area, one of them would do what you want. So give your sparky a call.
    Macca
  5. #5
    To solder the thicker cables just use a small butane flame , take your time and feed solder into it.
    Don't get it too hot, Drill a hole in a piece of timber to hold the lug to be soldered
  6. The Following User Says Thank You to threedogs For This Useful Post:
    NP99 (13th October 2013)
    178 Post(s)
    One of these will set you back less than it will probably cost to go to a sparkie & gives you the convenience of not having to stuff around working out the exact length of cable ahead of time. You might find it surprising how many times you use it once the current job is completed.
    Cuppa
    That's precisely the tool I had. I sold it when I was done with my last truck.
    @ Flow never ever sell tools, cause the day you sell it will be the day you need it
    Money-fishing (14th October 2013)
  11. #9
    Easily said when you have a home and a shed threedogs. But if your home is your 4WD for a few month then every item needs to pull its own weight so to speak.
  12. #10
    Expert janderson's Avatar
    Bearii Vic
    just use a some flat steel hit with hammer along the middle then use a vice to finish of
    1st G60 Then MQ Now GU
