Bigrig
The rear panhard is rigid, but is a Stealth rod that was installed when I did the lift, so the diff centres in the back are all good also - if I go the bent arm from SE, swap the shocks and extend the rear pins (they are slightly extended now but not as much as the front), then you reckon a 30mm spring spacer installation is worth it?? I'd prefer that than stuff around with a new installation all round. I figure all that would see me about $8-900 out of pocket with a 30mm height increase ... and from the measurements done, that would see the car sitting about 145mm above standard (nearly 6") ...
