Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Bigger tyres , by how much does it effect speedo accuracy ?
    Expert Limmy's Avatar
    Hi Guys
    I got 33s on my car . I know the speedo isn't as accurate. What are average kmph it is out by ?
    I'm in the middle of resetting my dawes and needle valve
    thanks
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Gday mate. With a GQ going to 33" inch tyres, you will be travelling at 100km/h when your Speedo says 95. But as all Speedos are slightly different you may want to double check with a GPS.
    Also there are lots of websites with tyre size calculators, just Google away
    Hello from Under Down Under!
    It varies so much... my old patrol was 100% accurate with 33"s according to GPS. Same GPS on my new one and with the same 33"s on when my speedo says 100km/h I am actually travelling 110km/h
    My Speedo is currently 8k above actual road speed, so 33's will bring mine up smack on..
    Patrol Guru TimE's Avatar
    Canberra
    As mentioned above speedo readings vary from car to car, as a rule (ADRs) a speedo on a standard vehicle should under read, i.e. when speedo says 100 kph you are actually doing say 97.
    Use a GPS to check your actual to speedo reading. On my GU IV I replaced the speedo cable cog at the gearbox from a 16 tooth to a 15 tooth, the speedo now reads spot on with the three different GPS units I have checked it against.
    This thread is worth a read
  6. #6
    Aug 2011
    North West Tas
    56 Post(s)
    What I posted was the ratio change as stated on tyre size calculators.
    But yeah if you do 100 on the Speedo in ten different standard vehicles you'll get ten different actual road speeds
  7. #7
    would it be safe to just drive under 5kmph ?
  8. #8
    Western suburbs of Melbourne
    12 Post(s)
    Quote Originally Posted by Limmy View Post
    Perfect. That's at a hundred k's.
  9. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    Limmy (3rd October 2013)
  10. #9
    thanks all for advice! just another thought.
    how much off would it be with 35inch ?
  11. #10
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    I went from 31's to 33's on the GU and now the speedo is spot on against at least 2 gps'
    used to read slower before....
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
